Ebl flash tune
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ebl flash tune
Ok so i just dumped 490.00 bucks for this stupid efi tuning ecm and well come to find out it still doesnt help im a brand new tuner first time ever doing this s***. for 490.00 bucks i expected it to be kinda plug and play but apperently it isnt for one there are no basic bins/programs in the ecm to even start the car to have a base line of where to go from there like i dont freaking get it can anybody help me out before i return this thing and get my money back
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
wow, relax a bit. As delivered the EBL ECMs have a base BIN is every bank. With the EBL Flash product (the one you purchased) there are an additional 30-some BINs included with the system.
Four of those are specifically for TPI engines.
Insert the EBL CD and the install dialog should open, finish that install. There will be two Desktop shortcuts created along with an EBL Flash Program Group. From there can open the help documents along with opening the user BINs folder.
See the Intro to Tuning Parts 1 & 2 on our website. The first is a tutorial on getting started with TunerPro and the What's Up Display (WUD).
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
RBob.
RBob.
Re: Ebl flash tune
Yea well thats the thing i been trying to get this thing to communicate for the last 4 hours u dont wanna respond to my emails etc etc etc like why cant u understand im brand new to this like i wanna learn how to do this but i have no body to help me out i finally got how the bins to pop up in tunerpro but now i cant get none of the com's to open or the red indicator to tell me that the wud is recieveing data from the ebl
Sometimes it takes my laptop a minute to find the com port- seems like that happens right after Windows does an update. Try going through the control panel > hardware and sound > device manager. See if your computer is able to identify the port it is hooked up to.
BTW- You did get it wired in correctly, right? You hear the fuel pump kick over when you rotate the key forward, right?
Engine: LR4 4.8
Re: Ebl flash tune
The com port thing can be frustrating. And that's a problem with your computer- not EBL.
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
Your first email came in at 8:21 PM (last night). Then two more later. Contrary to popular belief I do sleep from time to time.
As for the USB/Serial adapter, the included CD has the install instructions on it along with the required drivers. The product page for the USB/Serial adapter on our site also has a link directly to FTDI for the same information.
As for getting the USB drivers installed. Look at the instructions for the O/S you are running on your laptop. Due to changes Microsoft made the install varies among the different versions of Windows. And when doing this only plug the USB/Serial adapter cable into your laptop. Leave it disconnected from the ECM.
Also, some laptops have the FTDI drivers partially installed. This causes all kinds of problems. So may need to uninstall the current driver, then proceed to install fresh from the CD.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
RBob.
RBob.
Im sorry for getting upset i just really wanna get this damn car running its been sitting for almost 3 years and all i can do is crank the motor to let oil build up and keep everything lubed i actually wanna hear this new rebuilt motor run and run strong
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
Yes, note that you do need to select the com port assigned to the adapter in the WUD. Link to page that shows how to see which port to use:
http://www.dynamicefi.com/USB2SerialSetup.php
I do need to ask, is there a reason it wouldn't run with the stock ECM? Also, be sure to go through the sensors with the WUD and make sure that they are reporting correctly before trying to start the engine.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
Make sure that the CRS and MAT/IAT read close to each other and at the ambient temperature.
As for which BIN to use, try the 3006 (5.7l stick, TPI). It has more spark advance then a truck Vortec BIN, but it is likely OK in the lighter GTA. If you have larger injectors should change the BPC vs VAC table to accommodate them.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
Yep, connect the comm cable to the EBL and do a key-on, engine-off. The spinner should start as data arrives. Push on the go-pedal and the TPS% vertical gauge should follow. The MAP should be around 102 KPa, if you have a mity-vac can connect it to the sensor port and lower the KPa reading.
RBob.
RBob.
Next question what is the bpc vac table like i said totally new to this and also on the tps sensor should i only have power on pin c which is the .5 volts or should the the other 2 pins have power as well
Last question how do i go about wiring in the ac compressor wiring since i have no power to that as well
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
An IAT is a MAT that has been relocated.
Need to use the EBL Utility, it will calculate and allow a copy & paste of the BPC vs VAC table values.
Pin A will be ground, pin B will vary with throttle position, pin C will be +5 volts. Pin C is where to tap in to power the MAP sensor.
Nothing to do with the ECM. The ECM only gets the A/C active signal from the compressor clutch to know when to enable the fan.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
As I posted use the EBL Utility, it was installed onto your laptop. The Help dialog explains the entries. Once the information is entered the BPC vs VAC values will be listed.
Can even copy & paste from the table into TunerPro.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
Ok bob im trying to add the bpc vs vac i added in the calculate number which is 179.00 from 0 all the way down to 60 when i add the 179.00 to all the multi tables and try to save it, it doesnt allow me to save the changes where am i going wrong now
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
Laptop security is set too high, need to run TunerPro and the WUD as an administrator. Close them, then right click on the Desktop shortcut. From there need to find the line that states "Run program as Administrator."
It may be in the pop up menu, or select the Properties entry and under the compatibility tab. Check-mark that line once found (varies over the various Windows versions).
Once that is done may need to reboot.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
RBob.
RBob.
Next question is how do i go about deleting egr and tcc since i don't have egr hooked and im running a t5 so no tcc is there do i just go and delete the tables or should i leave them
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
The EGR is already disabled in the supplied calibrations. As for having a stick trans, un-check this flag:
Option Word 2 - Bit 7 - TCC
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
hey another question now that I got mostly everything hooked up and working right how do I go about getting the car to idle smooth it also seems that it running way to rich do I use ve learn table or totally something else
Engine: LR4 4.8
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
TunerPro:
IAC - Idle Speed: Drive
IAC - Idle Speed: Park/Neut
Once the engine is up to temperature can then adjust the idle stop screw to get between 20 and 25 steps. This is with no other loads on the engine.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
Ok so what would i set it to exactly in tunerpro do i just increase it by like 5 and see how it is from there
Car: 1985 Camaro Z28 IROC
Engine: 5.0L TPI H.O. 215HP STOCK
Axle/Gears: GU6=3.42
Re: Ebl flash tune
Howdy all,
Reading all these posts, I'm wondering if I too should take on the challenge of a PLUG-N-PLAY unit. Is all this frustration really worth 20-25 HP? I have never heard anyone having this much trouble with a carb set-ups. How much power can be had by tweeking the ECM on a TPI??
Car: check
Engine: check
Transmission: check
Engine: LR4 4.8
Re: Ebl flash tune
Ok so i was playing around with it and it kinda smoothed out a little bit i think timing is a little off so i think i gotta get that dialed in correctly also now seems like its running way to rich. One thing i did notice is there is no slight hez when touching the gas quickly climbs right up with no pause but i think timing is still off what do u think can still be wrong with it
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
How are the VE Learns going? Need to get the VE roughed in before moving on to other tuning items. Check the BLM values, if far from 128 need to do more learns.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
Ok so come to find out im way to advanced on base timing if that makes sense thats with the ecm plug bypassed it does fire up and run but not a smooth idle at all
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
Set the base timing to 8* BTDC, also set that in the BIN, this parameter:
SA - Initial SA
This is to be done on a warm engine with the EST/BYPASS connector open. Once this is done all further timing changes are to be made in the BIN.
RBob.
SA - Initial SA
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
Yea i finally got to playing around on it last night instead of 8 btdc inset it at 6 btdc and it fired right up motor only turned have a turn and ran on its own after ill do these adjustments to the bin and then go from there
Engine: LR4 4.8
Re: Ebl flash tune
Ok so i played around with it set it at 6 degrees btdc and let it warmed up idle was still crappy even turning the dist after it warmed up to about 200 degree i turned it off disconnected battery plugged in est bypass hooked bat back up and tried starting it and it didnt want to run where the hell did i go wrong now rbob im really about to send it to a tuning shop and let them deal with it cause im getting fed up
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
I'm not sure of exactly what you did. Sounds like you set the base timing to 6* BTDC, then changed it after the engine warmed up? What does the spark timing do once the EST/BYPASS is reconnected? Does it go advanced or retarded?
It is beginning to look like there are mechanical issues with the engine.
RBob.
RBob.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Ebl flash tune
I just read this whole thread, my goodness lol...
Can you at least upload a copy of the bin you're using to look at...?
Originally Posted by soarestransam
Ok so i played around with it set it at 6 degrees btdc and let it warmed up idle was still crappy even turning the dist after it warmed up to about 200 degree i turned it off disconnected battery plugged in est bypass hooked bat back up and tried starting it and it didnt want to run where the hell did i go wrong now rbob im really about to send it to a tuning shop and let them deal with it cause im getting fed up...
Re: Ebl flash tune
I am using larger injectors how do i go about setting the values like what numbers am i going to put in to make it run correctly
soarestransam is offline vBGarage Page Report Post
179 BPC? seems like smaller?
Are you using a vafpr?
Engine: LR4 4.8
Re: Ebl flash tune
I went by the ebl utility to get that number and also what is Vafpr I'll try to see if I can copy and paste it tonight or even try sending it a attachment
Car: check
Engine: check
Transmission: check
Re: Ebl flash tune
Craig, the BPC is fine as it is higher on port injected engines. Note that the FPR is vacuum referenced, which is stock for TPI engines.
A BIN can be attached directly, while a .dat data log needs to be zipped first.
I'm still not sure what you did with the distributor physical base timing.
RBob.
RBob.
Engine: LR4 4.8
Re: Ebl flash tune
ok how would I send the bin for everyone to look at
Engine: LR4 4.8
Re: Ebl flash tune
Ok rbob so im just gonna send it to a tuning shop to get this thing squared away now no matter what timing degrees i set it at it doesnt want to start or idle just bucks and chugs like terribly like i ****ed something up internally and if so im throwing in the towel on this freaking car i thought getting this ebl kit would have helped and made it easy for me to get this thing running the correct way but i guess not i should have just got a chip burned and called it a day but if u know anything else it could be i would greatly love to know if not then to the tuning shop it goes
Re: Ebl flash tune
GM engineers spend hundreds of hours on a tune. I remember reading in the book "All Corvettes Are Red"- the story of the C5 Vette- some of the trips out on snow and ice tuning the traction control didn't go as planned. Or even that the initial crash tests proved the chassis was too rigid and it killed the dummies (lack of crumple zones).
My point is this stuff- tuning- takes time. The more non-stock your car... the longer it will take.
When you take it to a shop, you'll eat a tow and then likely they will replace the ECM with another and throw EBL in the trash. If you want it to leave the shop running well... most shops won't likely mess with it because their business model is around efficiency and unless they are familiar with EBL- they won't have time to sit and play with it as long as you would.
This is almost an art.
If you look around at TGO and the tuning community here- some of the guys here you'll see are mechanics, racers, etc. The rest of us folks just know enough to be dangerous and to ask others for help.
I've been working on my tune for about a year and a half. I was also new to tuning. Sure- I had my SA table down in about the first six months... had bad IACs, a bad WB connector, needed a VAFPR, and a whole host of other things... but it has always been that: a learning journey. I'm working on small things nowadays. Like tweaks to AE. I'm pretty comfortable that I have most of it sorted out
I've been perplexed by all kinds of stuff. I've asked a load of questions. It's a lot of trial and error. Set up a BIN... datalog it... read data to confirm problems... make adjustments... revert back if I need it.
Tenacity- you need tenacity to get the tune where you want it. Tuning is NOT going to be an overnight epiphany for anyone who is new to it. Sure... you could get a decent burn from someone... or maybe not. It may run- but it might be too lean in PE mode- who knows. When you can't validate with data logging how do you know how good a mail order tune is? I'm not saying anything bad about tuners- there are some folks who are really good. What I am saying is that they will take their best guess from what they know and tools available- and will send you a chip.
With EBL- you can ALWAYS tweak the tune to your needs. And you can validate it with data (WUD). You can expand what it monitors (ADC channels).
And while you aren't seeing results yet- you are clearly getting frustrated. This isn't easy for anyone who hasn't done it before.
If anything, if you are still taking it to a shop... have the shop check to validate or set you base timing. If it holds a decent idle- leave the EBL in the car and limp it home. Everything starts with your basic mechanical settings. Then... move to VE learns and adjust it from there. You have a non-stock combination and the more non-stock it is... the more work you'll have ahead of you to tune it. There's only so much a stock tune can compensate for before you need to adjust things.
I know this wasn't what you wanted to hear.
But if you stick it out and keep at it... YOU WILL EVENTUALLY FIGURE IT OUT.
Don't let the challenges beat you- beat the challenges.
Re: Ebl flash tune
Hey soarestransam... I've looked over the BIN you attached.
For starters, your SA table looks identical to the BIN for an L98. Your signature says Vortec heads.
... you are going to have too much timing (from the L98 calibration) for your heads (Vortec).
Look for "EBL_F_3000.BIN: 5.7l Vortec Main & Extended SA Tables only" with the files that come with EBL and paste those SA tables into your BIN's SA tables.
If your engine is attempting to idle at or around 800-1000rpms between 50-70 KPAs and you are using the L98 SA tables... you have too much advance. Like 10-14 degrees too much.
See if that helps.
... you are going to have too much timing (from the L98 calibration) for your heads (Vortec).Look for "EBL_F_3000.BIN: 5.7l Vortec Main & Extended SA Tables only" with the files that come with EBL and paste those SA tables into your BIN's SA tables.
See if that helps.
Engine: LR4 4.8
Re: Ebl flash tune
See if that helps.
See if that helps.
Do you think because the plugs being burnt black would cause it not to start im just hoping i didnt lose compression or something mechanical failed dont fail like dumping 1000-2000 bucks on a rebuild this motor literally has like 5000 miles on it since tue rebuild in 2011
Re: Ebl flash tune
If the plugs are oily... you may have an oil problem.
If they are wet... you may have a compression problem.
If they are sooty... you are running too rich.
I would guess that your plugs are fowling because it is running too rich. When you advance the timing too far, you end up with additional unburnt fuel... which could explain your fowling plugs.
If your plugs were good previously, perhaps you can clean them off if they aren't trashed. Go ahead and use the Vortec spark tables. See if it will idle better. Then work on setting the minimum idle speed. After that, go do some VE learns.
Re: Ebl flash tune
Your Initial Timing is 6* BTDC in the bin, so make sure you set it there by hand and keep it there with the EST disconnected. Once you verify that is where it is on the balancer with a timing light, tighten the distributor, reconnect the EST, and don't touch it anymore. Your Idle SA is 20* BTDC which is fine, it goes hand and hand with the SA Main Table you are using. Pull your plugs, clean them off, reinstall them. Confirm your spark plug wires are on correctly and are in the correct firing order, confirm your fuel pressure is correct (43.5) and confirm your fuel pump is good and not losing pressure after key off. If all of this is confirmed, and you exhibit no vacuum leaks when idling, and you didn't touch any other value in the bin other than your BPC vs VAC, Initial SA and Idle State SA, then I would suspect it is somewhere in the data you are entering in the BPC Utility Tool; either the numbers you are entering are not being entered correctly, or the numbers themselves are flawed, meaning your injectors might not be what you think they are. Confirm your injector size, and if possible, give a screen shot of the Utility Tool information collectively...
Engine: LR4 4.8
Re: Ebl flash tune
Re: Ebl flash tune
Streetlethal thanks for the pic this helps out alot also corvette ill remove them and replace them for the 6 btdc ill set it at that and call it a day im going to use the 5.7 vortec bin and start from scratch now for plugs i cant use regular ac delco ones i need shorty plugs that accel use because if not they rub on the headers is there any other plugs beside the accel ones i could use
Re: Ebl flash tune
Oh- and check the gaps on your plugs too- make sure they all have the right gaps.
Keep at it...
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: Ebl flash tune
Mechanical/engine condition and component issues make tuning difficult. It all has to be right -first. I tuned for months before I figured out the plugs I was using were a tic too cold and due to my combo I was trying to run a little too rich and after a week or so of "progress" it would go south because the plug would start to foul. I would chase it for another week, or month until starting over. Then the weather changes and exposes some short cut I took and I end up starting over again. I also had to learn what to expect and what was acceptable for my combo. I tuned my prior engine for 2-3 years before building this engine and tuned it for about a year before going with the EBL. Now I have a little over a year tuning it and I have only recently been driving a certain tune for more than a day or two. My point is it does take commitment if I want good results. It's no different that carbs and distributors. There are lots of details with them too. It's not just jets but pump cams, air bleeds, float levels etc. But when I do start my EFI in the cold it runs with no operator input and runs consistent. In the end the EFI and EBL is worth the effort. But if you don't have patience, aptitude and stick with it you can't tune either one.
Engine: LR4 4.8
Re: Ebl flash tune
See if that helps.
See if that helps.
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Re: Ebl flash tune
Off subject of tuning but are you running the correct spark plugs for the vortec heads? They have a longer reach into the combustion chamber vs the standard sbc plugs.
Vortec plug on the left in picture.
