$8D memcal knock board ?
Old Nov 22, 2015 | 12:39 PM
Dr.E's Avatar
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
I am attempting to install KS in my $8D S_AUJP v4 1227727 ecm and I am finding some interesting problems. I am using Moates G1 adapter and EEPROM and when I set the bit for code 41 and run I get SES and code 41, So I tried the Jumper trick ASSuming that maybe I had a V6 memcal and now it runs horrible.
If I un-set the bit for code 41 runs fine. How do I verify what knock board I have?
Old Nov 23, 2015 | 11:22 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: $8D memcal knock board ?
Only way is by the BCC on it or the chip numbers inside it (with some digging)
Set the Error code bit to "ON" so you can see if the error occurs.
Set the value of "Cylinder Select" to 00 (Indicates V8 application)
If you get SES 41, Your MEMCAL is probably V6. (make the jumper change and try again)
If no SES and runs like crap, you are ready to begin tuning.
Old Nov 23, 2015 | 11:39 AM
91zl98's Avatar
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
https://www.thirdgen.org/forums/diy-...d-density.html
http://www.gearhead-efi.com/Fuel-Inj...your-Memcal-ID
