Bosch injector offset
Old Nov 20, 2015 | 11:52 PM
Dr.E's Avatar
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
No joy with the web search. Does anybody know where to find the injector offset for the Bosch 0-280-158-089 ? Stan Weiss site lists this as a 25.14 lb/hr @ 43.5 psi.
Old Nov 21, 2015 | 08:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Bosch injector offset
Unless they at one time or present are sold by Ford Motorsport there won't be compensation data. All these data sheets that are floating around are for injectors that Ford Motorsport sold or sells.
Even those with a performance shop water mark on it originated from Ford. They paid for the data and published it to support those that purchase their injectors (Ford).
RBob.
Old Nov 21, 2015 | 01:23 PM
Dr.E's Avatar
Car: 5500lb Brick
Is there any editing software that could be used to find the injector offset program values info in any of the Ford vehicles eg. 2011-12 Crown vic with the 4.6l v8 that these injectors were OEM? Ford service? Professional tuner with the equipment?
Thank you!
Old Nov 22, 2015 | 10:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I'm sure there is tuning software that can be used to extract some injector information. Off hand I can't recall what it is called. Possibly hit some Ford tuning boards.
RBob.
Old Nov 22, 2015 | 12:07 PM
ULTM8Z's Avatar
may want to try searching on the term "lag time" as well... during my research on this, I found that term being used to describe the voltage offset...
Also, looks like some cross reference Ford p/n's are 6W7E-A5A and CM-5119.
Good hunting!
Old Nov 22, 2015 | 02:51 PM
Dr.E's Avatar
Car: 5500lb Brick
Thanks for the info:
http://fordperformanceracingparts.co...9593-aa302.pdf
Not the same,but may be better starting point than what is in the Bin.
Old Nov 23, 2015 | 06:44 PM
Ronny's Avatar
gearhead forum?
Old Nov 23, 2015 | 07:47 PM
Dr.E's Avatar
Car: 5500lb Brick
Originally Posted by Ronny
gearhead forum?
Yes,same Dr.E
Abubaca
17
Dec 22, 2015 01:26 PM
kenty
Dec 14, 2015 05:37 PM
L98GTA87
Nov 24, 2015 06:18 PM
ULTM8Z
Nov 20, 2015 05:13 PM
NiG
Nov 18, 2015 04:24 AM
