How many IAC counts do you guys have at idle???
Old Dec 24, 2001 | 05:12 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
After I installed the 48mm TBI, my laptop crapped on me so I really didn't get any first hand data. I got WinALDL going again and now I find my IAC counts at idle are around 14! They used to be like 32 and 35.
The vacuum holds fine where it used to at about 33-35 kPa. Could I have a vacuum leak?
I opened the throttle plates a smidge with the adjustment screw and drove around like that for a while (laptop crapped again). Then last night I was on my way home and saw that the IAC counts were 0!!! It idled just fine as always, right at 575 RPM and 33 kPa.
Any thoughts?
Old Dec 25, 2001 | 08:00 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I like IAC counts around 10 at idle with car fully warmed up.
Old Dec 25, 2001 | 09:37 AM
87_TA's Avatar
IAC COUNTS
HI ASTRO,
In order to raise your IAC counts you need to close the throttle blades - not open them ,then restart the van you should look for counts close to 20.
Old Dec 25, 2001 | 01:21 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Yeah I know. The thing is if I close them too far the throttle plates stick in the bore.
Another friend of mine mentioned the throttle shaft bushings may be worn, if there are even bushings in there.
Old Dec 25, 2001 | 04:06 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
remember the bigger TB lets more air in. So with no changes you are gonna have less iac counts.
The lower the better with tbi.
Old Dec 25, 2001 | 07:05 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
V8,
I have the bored tbi units and 20-30 counts seems about right.
Old Dec 25, 2001 | 08:27 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Just as much personal preference as anything.
Personally I like the ecm having as little control as possible over the system. The IAC count applies also to the AE, and deceleration controls (dash pot effect) also. You'll have more throttle response with lower IAC counts.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Street Lethal
Aug 14, 2015 08:25 PM
