Want to read TPIS prom, what is this?
Old Oct 23, 2001 | 04:18 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I want to look at what TPIS did to the chip they burned for me before I knew I could do it myself. On the prom all I see is this:
980
1606 9300
BLDP9236 2117
I can't afford to ruin this prom b/c it's all I have right now to run the car with. What should I set my Pocket Programmer to so I can safely read this prom?
Old Oct 23, 2001 | 04:27 PM
v8power's Avatar
Is that on the actual chip or is that what on the sticker?
Just checking cause i can seeM to cross any of those numbers
Old Oct 23, 2001 | 04:46 PM
ryn28's Avatar
Engine: Chevy ZZ4
Those are the numbers on the actual chip. The 9300 appears under the #980 on the right side of the chip. Below on the left is the 1606. The #980 is across from that. Below that is the BLDP9236 and across from that on the same line is the 2117.
The sticker covering the erase area is plain white.
Old Oct 23, 2001 | 05:06 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by ryn28:
980
1606 9300
BLDP9236 2117
</font>
Lots of aftermarket chips have stuff moved around on them. So reading it maybe a waste of time anyway.
Always have 2 memcals, anyway.
If you screw up one, at least the car will run, using a lesser chip
Old Oct 23, 2001 | 07:54 PM
Tomcat's Avatar
9300 indictes it is a 27c128 eprom - thanks to http://www.cruzers.com/~ludis/p4pinouts.html
heaps of usefull info here.
Reading the memcal should not hurt it , although data may have been moved around so Tunercat etc may not read the tables correctly.
Old Oct 24, 2001 | 06:57 AM
ryn28's Avatar
Engine: Chevy ZZ4
[This message has been edited by ryn28 (edited October 30, 2001).]
Old Dec 26, 2001 | 03:16 AM
69TPI383's Avatar
Re: Want to read TPIS prom, what is this?
Sorry to drag an old topic back up (but at least I'm going thru some of the older posts ) but I was kinda curious what you found out if anything. I too bought a TPIS chip for a setup I'm putting together. It's not even installed in my car yet. I've been told the TPIS chips are basically crap (my words, not exactly theirs). I have a modified setup, (hyd roller cam 218*/224* 110*LSA, higher compression, better airflow, modded MAF, etc) so I was talked into their Level 5 chip. Now I'm about half paranoid this setup won't run right with the TPIS chip.
Just how good or bad are these chips? I *may* get into trying to burn my own chips but being a truckdriver I just don't have the time I feel required to learn how to do it or to get my settings optimized correctly.
Can somebody...anybody give me some feedback on this?
Thanks!!!
Old Dec 26, 2001 | 03:20 AM
69TPI383's Avatar
Can somebody...anybody.... please give me some feedback on this?
Thanks!!!
Old Dec 26, 2001 | 03:23 AM
69TPI383's Avatar
I'm not quite sure how that got double posted oh well...sorry guys!
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
