Can anyone explain this
What would explain different AFR numbers at WOT between 2nd and 3rd gear?
I've consistently logged an AFR of 11.8 at MAP97-100 between 3500 and 5000 RPMs in 2nd gear. However in 3rd gear at the same RPM and MAP the AFR is a near perfect 12.8.
How can I lean out the 2nd gear values without effecting what happens in 3rd gear?
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: Can anyone explain this
It's normal to have a difference due to length of time at the rpm but usually not so extreme.
What ecu/car are you working with?
I plan on writing a per gear fueling setup for 7730 ecu. But that's a ways out.
I am using EBL. It works great. I just have a lot to learn. The engine is a Pontiac SD4. Similar to the old iron duke, but about double the horsepower.
Car: check
Engine: check
Transmission: check
Interesting engine. Not knowing the conditions of getting to 2nd gear and flooring it. There may be too much AE, or that AE lasts too long that is adding to the richness.
As for 3rd being 1 AFR leaner then 2nd, that does seem to be a bit high. However, if the AE is correct you can use the enrichment over time logic. Will need to reduce fueling via the VE table to get 2nd OK.
Then attack in the enrichment over time so that as higher vehicle speeds are attained, the AFR is commanded richer:
PE - AFR Attack Enrich Over Time
RBob.
RBob.
Z28TPI305
Aug 19, 2016 12:59 AM
LT1Formula
Aug 15, 2016 09:25 AM
Jstewart1021
Jul 11, 2016 06:21 PM
