LC-2 wideband controller and Tuner Pro
Old Aug 2, 2016 | 01:39 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
Okay so next week I am finally ganna get my car on the dyno and though I have had everything hooked up and running for quiet awhile the guy that is ganna be doing the tuning would "Really like" the o2 to be readable on the tuning software making data logging and tuning easier/faster I know the LC=2 comes with a serial connector for this purpose but my lap top doesn't have a serial port and how would I go about making it view able in the software any help would be apricated
Old Aug 3, 2016 | 08:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: LC-2 wideband controller and Tuner Pro
Easiest would be to get a USB to Serial adapter cable and connect the LC2 to your laptop. Then use the Innovate software to display the AFR reading.
RBob.
Old Aug 29, 2016 | 10:27 PM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
Depends on the hardware too doesn't it? I was reading up on the Autoprom I have coming (Tomorrow! So excited lol). You are supposed to be able to set it up for one of the Innovate LC2 analog outputs and make it log directly to TunerPro with the rest of the datalogging you're doing. *Edit* (Sorry, I realized now this post is 20+ days old but I guess I was replying also to make sure I understood correctly as well.)
Old Sep 2, 2016 | 06:58 PM
tmellott89's Avatar
Car: 88 Iroc. 12.60@ 107. 1.72 60'
Engine: 350 paxton sn93 36lbs injectors
Axle/Gears: 9in. 390s
Yeah that's nice and easy feature with APU1. I have one myself with LC-2 hooked to it. Gearhead EFI forum has a really nice thread on setting up ADX file for it. Not difficult just time consuming. Also look into downloading logworks software from innovate so you can hook up straight to the wideband also. I say so bc mine is .5 afr off between log works and apu1, others have had this problem also bc voltage offsets. Not a huge problem but log works is right and once you know how far off it makes it real simple bc apu1 puts it in datastream. Just my 2 cents.
Old Sep 3, 2016 | 09:49 PM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Cool, thanks. That's good to go. I have lurked on that forum just reading for a bit now, I think I will probably be making an account for it here real soon.
FireDemonSiC
Feb 16, 2019 10:20 PM
hyde0970
Aug 2, 2016 08:38 AM
Scorched1984
Jul 27, 2016 11:58 AM
Skye1500CHEVY89
Jul 8, 2016 05:55 AM
