ALDL Cable Not Working - TunerPro RT
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Well, this is my last resort. Here is the breakdown:
- OBD1 ALDL Cable for ALDLCable.com
- TunerPro RT (Free Version)
- 1991 7730 running $59 for my turbo 3.1l
I had no issues last year connecting and tuning my vehicle. I had some issues with my laptop where it updated to windows 10, wouldn't handle it, so I downgraded it back to windows 7. This is the same laptop I used last year.
All the drivers have been installed correctly and TunerPro works with my Burn 2. I cannot seem to get it to detect my ALDL Cable though. The computer detects it, updated with the drivers from aldlcable.com, set the com port, etc etc. I keep getting the same error when I try to test it in TunerPro.
Any help would be fantastic. Thanks!
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Re: ALDL Cable Not Working - TunerPro RT
I do have another 7730 I can swap out and try, but shouldn't TunerPro recognize the cable? I'm wondering if the computer is faulty due to the other issues I have experience with it.
Transmission: 5-speed/T-5
So just to be clear, the "Test for valid cable" test responds with a "cable not found" result?
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Yes SixShooter, that is exactly it. Which leads me to believe it is a computer related issue as it recognizes the cable but TunerPro does not.
Car: check
Engine: check
Transmission: check
In this case I'd say that TP RT isn't set up properly. Can use the Device Manager to see which COM port is assigned to the cable.
RBob.
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Yes it is confusing me too. I will try and reinstall Tuner Pro and also try another laptop today.
It is set to COM 3, I also tried 1,2, and 4. No luck.
Here are the Tunerpro settings I'm running (I have a Dell Inspiron 640m running Win7)
Under Tools, Preferences, Data Acq./Emulation tab...
Interface type = Use Plug-in
Data Acq.I/O Plug In component = TunerPro Data Acquisition I/O Interface
Pushing the button for Configure Component, the dialogue box pops up and has Port Type = Serial and my port number = {COM5}
The two boxes are checked for Load last Data Acq Def at Start and Warn of ADX/XDF Link Mismatch.
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
ULTM8Z, my settings are same besides the port number. The port number does match in the preferences along with in the device manager.
I tried this again on another laptop and my desktop with no avail. I believe this may be a cable issue instead of a software issue. I called aldlcables.com and left a message.
I don't understand how the cable works perfect with no issues last year and all of a sudden is dead out of the box. Really really irritating.
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Well, I was able to get the cable to connect with an absurd amount of pressure on the usb connection. I believe there is something wrong inside the cable.
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Just to update and close this thread:
Contacted aldl.com, after a few emails and calls Ken got back to me today. They offer a one year warranty on the cables but I was out of that range. He offered to ship me a new one for $30 (half off) so I decided to go that route.
Not sure how long the car will stay obd1... haha
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
make sure to update us... I had trouble datalogging myself. Going to try this fix when I get my new memcal (which I THINK I fried)
https://www.thirdgen.org/forums/diy-...pro-rt-da.html
