(st 89014n) M27128-2f1 (pgm 12.5v)
Old Jan 2, 2002 | 11:34 AM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Can someone tell me if this chip is an EPROM (UV erasable) or an EEPROM (electrically erasable)???
Old Jan 2, 2002 | 02:36 PM
drive it's Avatar
Do you have it in front of you? It has to have a little "window" in the middle of it to be UV erasable. By the # I believe that one should be a UV and not "EE".
Old Jan 2, 2002 | 07:53 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
It is not a Flash Prom. The proper flash prom that works for our cars is the AT29C256. There are no "27" series Flash Proms that I am aware of. Also, Flash Proms generally only need 5 volts (or less), 12.5 would be an eprom (my guess) or possible a prom (program once) if there is no "UV Window" in the middle of the eprom or under the "silver sticker" which usually covers the window.
Old Jan 3, 2002 | 07:42 AM
87ROCZ's Avatar
OK I found out...
I found out that this PROM is a UV type.... Thanks for the responses!!
Old Jan 3, 2002 | 09:56 AM
formula5's Avatar
I have 2 questions,How much and what eeprom to use instead of the uv type(I use now).Can someone suggest a good place to get a pc programmer used.I'm going to buy one new if I can't find one.It's just saving maybe $50 would give me enough for a few eeproms
Old Jan 3, 2002 | 10:05 AM
Car: Death Mobile
Engine: 666 c.i.
AT29C256, about $6.00 each. Since they can re-burn them MANY TIMES more than an eprom, you won't need as many.
Old Jan 3, 2002 | 01:42 PM
Dan W's Avatar
27 indicates eprom, 28 is eeprom, not sure about 29
sahlomonic
Sep 20, 2015 07:15 PM
scottmoyer
Mar 16, 2015 04:27 PM
Slouch
Jun 14, 2008 06:29 AM
Zyth01
Nov 29, 2006 12:59 PM
Artem
May 8, 2004 03:56 AM
