Auxilliary 5V sensor ports on 7730 ECM?
Old Sep 22, 2017 | 08:31 PM
ULTM8Z's Avatar
Are there any other pins on the 7730 ECM that can read a 5V sensor and then communicate out to Tunerpro?
And if so, in Tunerpro, how would one go about telling it to look at that particular pin and report it out?
Old Sep 22, 2017 | 09:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Auxilliary 5V sensor ports on 7730 ECM?
A input like d4 maybe ?
Old Sep 22, 2017 | 09:34 PM
ULTM8Z's Avatar
In fact, is there a schematic of the 7730 somewhere I can get hold of?
Old Sep 22, 2017 | 09:37 PM
Engine: Lb9
Transmission: M20
Extratorq iirc use to have a post of the schematic.
http://www.vmeng.com/project-s/electrical/menu.html
Old Sep 23, 2017 | 10:52 PM
ULTM8Z's Avatar
Hmmm.... doesn't appear to be giving me the I/O list of all the connector pins...
I found this...
https://pcmhacking.net/ludis/quadplugecm.html
Looks like B3 is a 2nd MAT sensor; or a 3rd MAT sensor at E14. Maybe I could tap off of one of those...
The question then is how do I get Tunerpro to see one of those pins?
Old Sep 24, 2017 | 08:07 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It does, sheet 8 shows the three harness connectors. Sheet 3 shows how the inputs are configured.
Need to add firmware that will read the desired input and place it in a RAM location that can be spit out via the ALDL data stream. Then need to add that to TunerPro so that the proper value is displayed.
RBob.
Old Sep 24, 2017 | 09:34 AM
ULTM8Z's Avatar
RBob.
That sounds like an SAUJP update...
Old Sep 26, 2017 | 12:41 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
SAUJP already does that.
It's also easy to add it to any other $8D bin.
Old Nov 17, 2017 | 02:27 PM
Engine: Lb9
Transmission: M20
The link I posted with the internal schematic of the 730 doesn’t work.
Anyone know is f9 a v5 ref ? And is b8 12v ?
Old Nov 17, 2017 | 03:56 PM
ULTM8Z's Avatar
According to the pinouts in the link above,
F9 => U6-12 via 100 & 200K, CAL-29 via 100 ESC (100 & 4.02K to 5V)
B8 => ESC Tap (10K & 470K to GND) U13-15 via 10K, CAL-32 via 10K
Old Nov 17, 2017 | 04:52 PM
Engine: Lb9
Transmission: M20
Thanks I guess I overlooked b8 being listed.
Funny it says 4.02k when a sd ls is 3.9k must be close enough.
Old Nov 17, 2017 | 06:00 PM
Engine: Lb9
Transmission: M20
Do you know if a tpi maf esc module will work on f9. I think it uses a 100k ks.
Does it need higher voltage. How can voltage be changed in the reprogramming . Unfortunately I can’t read code but is there a hex address that can be changed ? I read that the 165 ecm puts out 9.3v koeo and running.
Of course with the memcals esc removed.
Old Nov 17, 2017 | 07:09 PM
ULTM8Z's Avatar
I have no clue on that one... Maybe RBob or one of the other experts knows...
Old Nov 17, 2017 | 08:05 PM
Engine: Lb9
Transmission: M20
I think chevythunder is wrong. b7 Pinout on a 165 is 9.3v and diagnostic shows below 6v.
165 must be a 5v ref signal ?
http://chevythunder.com/fuel%20injec...ecm%20#1227165)
http://www.chevythunder.com/maf_esc_module_code_43.htm
