Lost "View By" button in Tuner Pro
Old Oct 9, 2017 | 11:56 AM
83 Gman's Avatar
On main page of Tuner Pro, left side where it says Parameter Tree the "View By" button doesn't work.
I can't find away to restore it.
I don't have Scalars, tables or flags either.
Old Oct 9, 2017 | 01:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Lost "View By" button in Tuner Pro
Make sure that an XDF file is loaded into TunerPro. If the XDF was moved or delete4d TunerPro can't load it and that window will basically be blank.
RBob.
Old Oct 9, 2017 | 03:21 PM
83 Gman's Avatar
RBob.
How do I reload the XDF file? Should I use the set up CD again?
When I select the XDF buttom on the tool bar I choose the first item in the drop down menu "select XDF". When that opens there is nothing to select in that screen.
Right before I notice this problem I downloaded and installed TunerPro latest update.
When I start TunerPro a pop up windows says:
"Program can't start because MSVCR120.dll is missing from your computer. Try reinstalling the program to fix this problem"
I'm taking it as to try installing the up date again.
Old Oct 9, 2017 | 03:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I've seen that error before. IIRC, you are running XP or possibly Vista. What Mark did was to use Windows functions that didn't exit in the earlier Windows O/S.
Back out the current version of TunerPro and re-install the older version.
RBob.
Old Oct 9, 2017 | 04:12 PM
83 Gman's Avatar
I just went on YouTube and found away to reinstall MSVCR120.dll
Where do I look to install older version?
Edit:
Went to TunerPro and download file dated 11/26/15. Still have no XDF file to select.
Is there a way to manually install this file?
I'm using Windows 7.
Old Oct 9, 2017 | 05:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can find your gm xdf here
http://www.gearhead-efi.com/Fuel-Inj...ams-Tuner-Info!
http://www.tunerpro.net/downloadBinDefs.htm
Old Oct 9, 2017 | 05:46 PM
83 Gman's Avatar
Thanks for the links but I don't know which file to choose in the GM list.
Old Oct 9, 2017 | 05:49 PM
Engine: Lb9
Transmission: M20
What are you working on ? Ebl ??
Old Oct 9, 2017 | 06:27 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
You will have to browse to the folder that you saved your XDF in to load it.
Old Oct 9, 2017 | 11:40 PM
83 Gman's Avatar
What are you working on ? Ebl?
Yes EBL it's the EBL P4.
Old Oct 9, 2017 | 11:47 PM
83 Gman's Avatar
That folder is empty.
Old Oct 9, 2017 | 11:49 PM
Then you didn't save the XDF, like I said you need to browse to the folder YOU saved the XDF in.
Old Oct 10, 2017 | 12:28 AM
83 Gman's Avatar
OK I think I solved it. Went into C drive program files and found EBL_P4_v10.XDF I copied and then pasted it into the program file for TunerPro. I now can read Scalars, flags and tables.
