need help. APU1 and TP bin file save as VLC player file. Why??
Old Oct 26, 2017 | 04:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am trying to read and save a 27SF512 chip using a APU1 and Tunerpro. For some reason, the file saves as a VLC Player file. Its labeled as .bin but I sent it to a member here to read and it will not open. What am I doing wrong?
Old Oct 26, 2017 | 04:43 PM
Drew's Avatar
Re: need help. APU1 and TP bin file save as VLC player file. Why??
*.bin is a file extension that is associated with VLC player. You can associate any file extension with any program, it doesn't change the file, just the icon used and the program windows thinks it should use to open it.
Old Oct 26, 2017 | 04:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
So the person I sent it to should be able to open it? Im a newb here with this stuff.
Old Oct 26, 2017 | 04:48 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It’s been awhile since I’ve used a apu1. You should be able to use flash and burn read as a 27c256 then save buffer . The extension would be a .bin
Old Oct 26, 2017 | 04:49 PM
Engine: Lb9
Transmission: M20
If your trying to post it on a thread you will need to zip the file.
BOTTLEDZ28's Avatar
Transmission: A4
Im about a week into learning this stuff and I think Ive only consumed about 3% of the info that out there to learn. With that being said, what is flash and burn? Is it a program I need to download?
I was trying to send it via email to a member here so he could look at it.
Old Oct 26, 2017 | 04:52 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am trying to send the file to ULTM8Z (Mike). I dont think he is familiar with Autoprom
Old Oct 26, 2017 | 04:53 PM
Engine: Lb9
Transmission: M20
Flash and burn is a stand alone program used for the apu1 and burn products.
http://support.moates.net/flash-n-burn/
Old Oct 26, 2017 | 04:55 PM
BOTTLEDZ28's Avatar
Transmission: A4
Thank you. I am not familiar with that . I will look into that now.
Old Oct 26, 2017 | 04:56 PM
Engine: Lb9
Transmission: M20
I think it’s easier to do a read that way than using tp, if you read it as a 512 you need to set the offsets. So read it as a 27c256
Old Oct 26, 2017 | 05:00 PM
ULTM8Z's Avatar
Tuned,
Does it matter what the buffer start address is when he does the "read chip"? He's trying to read in a 27S512 chip and hte buffer start is currently 0000. In the screen shots he sent, that's the only difference I detected from how I work it on my minipro burner... I use 08000
Old Oct 26, 2017 | 05:01 PM
BOTTLEDZ28's Avatar
Transmission: A4
It is asking me for chip start address and finish address as well as buffer start and finish.
There is no list of chips in the supported chips window.
I changed the start to 08000 earlier and it still saved as a VLC file. I never bothered to sending it to you.
Old Oct 26, 2017 | 05:05 PM
Engine: Lb9
Transmission: M20
If you read as a 256 you don’t need the offsets . The 512 offsets are here.
http://support.moates.net/programmin...using-offsets/
000000 -> 007FFF
008000 -> 00FFFF
I don’t know why it’s not saying supported chips
Old Oct 26, 2017 | 05:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
000000 -> 007FFF
008000 -> 00FFFF
I closed the program and restarted it. supported chips are now listed.
Old Oct 26, 2017 | 05:09 PM
ULTM8Z's Avatar
008000 -> 00FFFF
Ok, so I think the answer to my question is yes
Old Oct 26, 2017 | 05:10 PM
Engine: Lb9
Transmission: M20
Right on ! Making progress
Old Oct 26, 2017 | 05:11 PM
ULTM8Z's Avatar
Try sending to me. It may work now.
BOTTLEDZ28's Avatar
Transmission: A4
I sent you the file that was read and saved using the FLash N Burn software. It still saved it as a VLC file though.
Old Oct 26, 2017 | 05:13 PM
Engine: Lb9
Transmission: M20
Sorry I never saw your question but yah those are the correct offsets or reading as a 32k does the trick no other offsets needed unless the default was set to burn a 16k file 27c128.
Old Oct 26, 2017 | 05:16 PM
ULTM8Z's Avatar
Success!
The one with the start address at 08000 works.
Old Oct 26, 2017 | 05:17 PM
Engine: Lb9
Transmission: M20
Can you even rename with newer windows to change the extension ? (Vlc to .bin )
ULTM8Z's Avatar
apparently... It opens just fine in Tunercat
Old Oct 26, 2017 | 05:19 PM
Engine: Lb9
Transmission: M20
Success!
Large file 64k with the incorrect offsets ?
Old Oct 26, 2017 | 05:24 PM
ULTM8Z's Avatar
no, its still a 32kB file..
Old Oct 26, 2017 | 05:25 PM
Engine: Lb9
Transmission: M20
Weird but glad you can read it now
