DIY Prom '85 tpi. Help
Car: 1985 Iroc
Engine: 305 tpi
I am new to this Prom tuning deal. I have read several threads including intro to prom tuning. I can't get the link to work for the xtronics.com programmer. Any help would be greatly appreciated. Thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: DIY Prom '85 tpi. Help
You might consider going to the 165 ecm. Or using a adapter to use 27sf512 eeproms and a moates.net burn 2.
https://secure.transtronics.com/I-PP3USB.htm
A pp3 you can burn 2732 proms
Car: 1985 Iroc
Engine: 305 tpi
Engine: Lb9
Transmission: M20
The p3 will work with uv erasable proms. I would look into doing a 870 to 165 ecm upgrade.
Engine: Lb9
Transmission: M20
http://f-body383.tripod.com/AAB/870-...pRepinning.htm
The 1227165 ecm was used in 86-89 tpi maf
https://www.eecis.udel.edu/~davis/z28/ecm_swap/
87TAinAK
Jun 7, 2006 02:31 PM
PLANT PROTECTION
Dec 30, 2002 10:21 AM
