Locked BLM/INT in Closed Loop but...
Car: '87 Formula
Engine: Ramjet 350
... BLM still seems to change, at least as reported by TP.
I am using the settings shown below.
Re: Locked BLM/INT in Closed Loop but...
It may be remembering what the BLM was in those particular cells and using that to apply a richening fudge factor ( if the BLM was higher than 128).
In SAUJP, there's a flag that you set that forcibly locks the BLM to 128 in PE.
Car: '87 Formula
Engine: Ramjet 350
Kind of what I'm thinking.
I do have option for locking BLM to 128 in PE set (see below).
I'll try resetting ECM to clear out anything it may be 'remembering'.
Car: '87 Formula
Engine: Ramjet 350
I feel like this may be a TP/Dashboard thing. Oddly, every sample in the History Tables is 128.
Darkshot
09-03-2006 08:53 PM
327_TPI_77_Maro
04-24-2005 11:47 AM
