BLM/INT locked to 128...
Car: 1990 Corvette
Engine: 415
Transmission: six speed
Axle/Gears: Dana44 3.73
Hi all
just for interest...
When i lock the BLM and INT to 128, are there still corrections made, when the ecm switches from open to closed Loop?
ECM 727, $8D
or is this "closed Loop with open Loop values and no corrections"
thank you
ECM 727, $8D
thank you
Car: check
Engine: check
Transmission: check
Re: BLM/INT locked to 128...
The proportional gains are still active. With the short and long term fuel trims being locked in place (INT & BLM).
RBob.
RBob.
Car: 1990 Corvette
Engine: 415
hi RBob
does this mean, that corrections to the VE tables (fueling over all)are still applied?
thanks
thanks
Car: check
Engine: check
Transmission: check
The proportional gains are used to force the AFR to oscillate.
There won't be any fueling corrections as the INT & BLM are locked at 128.
RBob.
RBob.
Car: 1990 Corvette
Engine: 415
thanks!
so, this would be a form of closed "open loop" only difference would be the closed/open loo flag in Datamaster?
anyway, this is as i said, just for interest...
it seems, i cannot make the engine happy in closed loop, will try open now!
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
