EBL Bench Test
Old Jul 16, 2018 | 11:47 AM
billvv's Avatar
EBL Bench Test
I'm planning on installing my GM TB EFI with EBL system later this year, but would like to get some practice with its operation while it's sitting on the bench. I have a harness with sensors attached. Which pins need power and ground to fire it up, load BINs, etc.? Any cautions?
Once I'm familiar with it, I plan on installing it for spark only, plus sensors, at first to try and solve a backfire through carb issue, then fuel when I can find enough time to make some intake manifold changes. Thoughts?
Also, while I can use the WUD display going down the road, can anyone recommend a modern gauge graphics program for display and alarm (not tuning). I assume this would utilize the ALDL port on the ECM to harvest the data.
Old Jul 16, 2018 | 11:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Bench Test
Need battery on pin B1 and/or C16
Need ignition on pin A6
Need ground on pin A11, A12, D1, or D2
RBob.
Old Jul 16, 2018 | 04:31 PM
billvv's Avatar
Re: EBL Bench Test
Got it! A couple of the harness wires were a different color than the diagrams... Thanks.
SATURN5
107
Apr 23, 2012 04:25 PM
JPrevost
41
Nov 12, 2004 05:15 PM
SATURN5
Apr 9, 2003 11:16 AM
Chop_Top
Oct 16, 2002 05:00 PM
