Moates Burn1 blewup?
I have had a Burn 1 for some years now and it has always worked well. Recently it will always give me the "FAILURE: Verification Failed (not matched)" after programming a tune onto a chip. Have reinstalled drivers and tried two computers still the same effect. Chip offsets are good, I have 10 chips.......
I think something must be wrong with the burner itself. Has anyone tried to contact Moates these days? I have been calling for days now and they will not answer or return phone calls..... What is going on?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Moates Burn1 blewup?
Try sending them a email. They have been quick to respond in the past.
Transmission: 5-speed/T-5
Are you erasing the EEPROM first? You'll get a failed verification if you're not programming a blank EEPROM.
Got a BURN2 in the mail today. Everything is good again. Looks like the BURN1 did in fact blow up. I tried to reflow the solder on the VPP pin of the burner as per their recommendation and that didn't fix it so I sent it back and ordered a BURN2 via the Express RMA procedure.
Wishmaster's87IROC
May 22, 2011 12:21 PM
tazextreme3
16
Aug 30, 2010 09:47 PM
White25thZ28
Sep 4, 2009 05:05 PM
