1995 gmc truck tuning
Re: 1995 gmc truck tuning
I have chased this rabbit for some time. Best option is to find someone who can do a custom tune (moates autoprom) after driving around and data logging. I have a 1994 I use for toy hauling, our 4l60e's differ in a way, TCC Lock up. I ordered a Sonnax Cure kit , this is the link for the 95+ kit --> (https://www.sonnax.com/parts/3029-the-sure-cure-kit) because our early 4l60e's were prone to Valve body wear and Accumulator Failure. The Sonnax kit comes with upgraded steel plates to prevent wear in the ball check guides. $250.00 for the complete kit and new accumulators (1-2 harsh 3-4 soft // Complete loss of OD was common symptoms of Valve Body Failure). Your 1995 PCM is the preferred unit for Tuning IIRC also. I also recommend Bypassing your factory Oil Cooler, being integrated into your Radiator, the factory mech. fan did a poor job of Pulling air through shroud IMO. I switched to an auxiliary cooler and dual ls1 fans, keeps the truck nice and cool after those long trips up-hill.
Car: 1983 G20 Chevy
Transmission: 4L60
Slash
10-14-2016 06:27 PM
jrlanham
10-10-2016 07:13 AM
