Mini Programmer Help please
Old Sep 1, 2018 | 03:13 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
My Mini programmer has burnt me many successful chips. I have mainly done 6e (16kb) and used a 27FSST 512 EEPROM. On the mini programmer you simply select chip start as shown, for 16k it is 00C000. This places the data at the end of the chip and works 100% of the time.
I am currently trying to burn a axxyd chip (32kb) SD '90 and select 008000, as I am also using the 512. I seem to be getting the correct data and with it in the right place ie at the end. I notice a lot of the cells are filled with 00 as pictured. Is this correct- it looks the same in Tuner RT in the hex cells.So far te chip has thrown a SES code and the car goes into limp home.
Attached Thumbnails Mini Programmer Help please-burner-settings-16k.png   Mini Programmer Help please-080000.png
Old Sep 1, 2018 | 09:06 AM
ULTM8Z's Avatar
Re: Mini Programmer Help please
https://www.thirdgen.org/forums/diy-prom/713259-anyone-using-minipro-chip.html
buffer start should be 08000
clear buffer with 0000
Old Sep 1, 2018 | 03:15 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
L
E
G
E
N
D
Will give it a try. Thanks
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
08000 and not 008000? Moates says the latter
Old Sep 1, 2018 | 03:17 PM
ULTM8Z's Avatar
I use 08000 with my 27s512
erummel
84
Dec 3, 2010 08:25 AM
erummel
96
Mar 6, 2010 05:42 PM
2fast4love
Dec 1, 2008 03:45 PM
2fast4love
Nov 30, 2008 08:13 AM
436efi
Oct 12, 2007 10:21 PM
