please help mini ram 383 afr headed
Old Nov 29, 2008 | 09:49 PM
2fast4love's Avatar
ok i recently bought a 383 iroc with a mini ram on it it also has a zz 383 cam in it with 1.6 roller rockers. well the problem is the car has the idle surging i already cleaned the iac sensor and replaced the spark plugs and its the same. i also adjusted the tps to 52 and the the fuel pressure is at ideal. i have thrown a maf code once while driving and it disappears after the car has been restarted. im killing myself for this please help also its and 88 thanks everyone
Old Nov 29, 2008 | 11:13 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: please help mini ram 383 afr headed
What MAF code did you get? 33 or 34? When you checked the fuel presurre after shutting off the car how long does it take to bleed down to zero?
Also how does it run with the MAF unplugged?
Old Nov 30, 2008 | 12:03 AM
2fast4love's Avatar
it usually takes a while to bleed down longer than an hour also the guy that i bought it from said he replaced the fuel pump with a high flow unit. the code that shoots out is 33 i diconnected the maf today and started it, the car hated it and instantly poped up the code. any help is appreciated thanks
Old Nov 30, 2008 | 08:13 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Assuming you have no vacuum leaks hint hint this question would be better researched at the prom board.
I've been fighting for nearly a year on and off with my 383's idle surge problem. It has taken me playing with idle air, idle spark, O2 switchover points, throttle follower, and a few other tweaks to get it to idle nearly surge free.
evilstuie
Jan 9, 2020 08:29 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
