Throttle Body Question
Old Nov 27, 2008 | 08:18 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
I just bought a 58mm BBK throttle body and it is a little different then my stock throttle body. On the side where you hook up the throttle and cruise control cables, the arm there is different. Did I get the wrong throttle body? I have a 1992 formula, is this one supposed to be for the earlier tpi motor?
Old Nov 28, 2008 | 10:21 AM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Re: Throttle Body Question
Send it back, or change your throttle cable.
Old Nov 28, 2008 | 10:24 AM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
well i would but I bought it used. It is like new but I dont think it will work on my car. I think this Throttle body is for the earlier TPI cars. Is there anyway to switch the levers?
Old Nov 28, 2008 | 08:37 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
can't switch them, just buy a throttle cable for a pre 89 tpi, thats what i did. only difference is the progressive rate of the pedal, i personally like the older style better, it has a smoother pedal flow.
Old Nov 28, 2008 | 08:45 PM
Hunnicuttz's Avatar
Car: 1992 Formula
Engine: 5.7 350
Yeah I think I will have to switch the cable. I wish I could trade someone for the right TB i'd even trade for a 52mm.
How hard is it to switch the throttle cable?
Old Nov 30, 2008 | 10:52 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
It's not a real problem.
Start under the dash at the pedal.
The cable hooks up on top of the pedal assembly, then pops through firewall.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
