Money in the bank, what should i do?
Old Nov 26, 2008 | 07:25 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
Hey yal,
So here's my dilemma, I have about 2g's that happen to be burning a hole in my pocket. I really want to make this into a mean, efficient (especially on gas, which may not be possible I don't care) street machine. What mods can I do, to get some really ponies outta this 350. I read a thread once that someone said work from the rear-end to the engine. Its better to mod a engine when you have a built rear-end to support it? Do you guys follow this idea or should I do something else?
Thanks, 3rd
Old Nov 26, 2008 | 07:34 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Re: Money in the bank, what should i do?
Headers, better exhaust and cam. Then new injectors, AFPR, plenum porting, followed by better heads.
Old Nov 27, 2008 | 07:11 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You really should give the money to me. I still need a trans brake and a new rear when I blow it up.
Seriously though, the drivetrain can handle plenty of power before it starts breaking. Technically you should start with the braking system. It does you no good to get the car moving if you can't stop it before driving up under somebody's lifted truck.
After brakes, hit the exhaust and then the intake. You gotta make it breath.
Old Nov 27, 2008 | 11:39 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you're like me, and seldom scrape together much more than $1,000, then do the heads first, while you can. I'd say AFR 180s, as these can be sent back to AFR to be CNC'd up to 195s if you ever go 383.
Old Nov 27, 2008 | 01:31 PM
3rdgenred's Avatar
Atila,
I was think of doing a 383 stroker build, but not til after I get outta college and get a real job. If thats the case, what heads would be good for a temp 180cc that I can then bump up to a 195cc? And inst aluminum better that steel? Sorry if I seem like such a noob, I build computers, not cars, but im willing to do whatever it takes to learn.
Thanks, 3rd
Old Nov 27, 2008 | 08:48 PM
77tpi nova's Avatar
save your money, dude.
or nitrous kit
Old Nov 28, 2008 | 12:55 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
The best thing you should do is a cam, heads and new exhaust from the headers back.
Old Nov 28, 2008 | 04:07 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I say save your money until you come up with a concrete idea and
a blueprint of sorts for the motor. Take the car off the road, build it
and tune. Anything else is just frustration and listlessness.
Doing it piece by piece is problematic, especially for the uninitiated!
If only I could go back four years... I wonder what kind of power
I would make now and the money saved if I knew the stuff I do now..
77TPI and Viprkilr got it right.
I like the idea of touching the brakes and the other essentials to
a daily driver, money well spent in that area. I love when my car is
clean to the touch, a smooth ride and nice brakes.
Old Nov 28, 2008 | 05:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
save alittle more and do cam heads intake but only if your bottom end is still pretty fresh. High mileage i wouldnt do it
Old Nov 29, 2008 | 02:01 AM
the blur's Avatar
invest it in the stock market. it's at rock bottom.
Old Nov 29, 2008 | 09:56 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Besides the above, and saving $$ 'til you can do a "package" build, consider purchasing and learning to use tuning (chip tuning) equipment. There is probably a good bit of power to be had by giving a stock engine a good tune, and you will need to be able to tune progressively as you continue to build the engine. I am just of recent beginning to learn tuning, and I really, really wish I had started before I ever put a wrench to the car.
Bill
Old Nov 30, 2008 | 10:58 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Buy the stuff to do your tune yourself and save the rest of the money.
You'll have a good dependable car that gets descent mpg.
InfernalVortex
Apr 20, 2021 11:31 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
