Water meth injection using EBL
Old Oct 13, 2018 | 09:24 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Installing a DIY water meth injection for my car. Primarily to use with nitrous but it could be a benefit NA.
1. Considering controlling it via the "PE active" out put. WM injection would be active anytime under load which covers N2O operation as well. Any comments about going this route rather than just in parallel with nitrous. Besides, the nitrous is progressively controlled so the WM injection would be progressive as well. It can be done since a spare nitrous solenoid will be used for the WM injection control. Seems PE would be easier and extend the usage.
2. Using PE active output I presume would be the same circuit as wiring for the nitrous or shift light. Use the output as the ground side of a relay which carries the pump/solenoid load.
Old Oct 14, 2018 | 09:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Water meth injection using EBL
This is correct.
RBob.
BANDITSBC
May 16, 2012 08:32 AM
Batass
Jan 8, 2009 10:57 AM
daves12secV6
Fabrication
Mar 15, 2007 10:24 PM
daves12secV6
Jan 3, 2007 04:14 AM
slapi01
Oct 30, 2006 09:24 PM
