Tuner pro rt and wb
Old Oct 27, 2018 | 01:07 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Tuner pro rt and wb
So i have a question, i have a plx wide band and would like to do this it does have a analog wire, i sued it on my hptuners, but how would i build the table in tuner pro rt?
and what values should i use, i know engine speed vs what?
Old Oct 27, 2018 | 04:27 PM
ULTM8Z's Avatar
Re: Tuner pro rt and wb
kinda short on details...
what year car?
what ECM?
what broadcast code? i.e... AUJP? ANJF? etc...
TP already has all that functionality in it if you use the S-AUJP suite of files... bin, xdf, and adx. but you have to have a 90-92 system in order to use that.
Old Oct 27, 2018 | 04:37 PM
happyhapka's Avatar
what year car?
what ECM?
i have an 86 maf. 350 TPI.
165 ecm.. im running the aujm bin.
Old Oct 27, 2018 | 05:11 PM
ULTM8Z's Avatar
unfortunately I'm only familiar with the 90-92 stuff....
Old Oct 27, 2018 | 05:15 PM
happyhapka's Avatar
hopefully some one knows, would make tuning even easier
Old Oct 27, 2018 | 09:24 PM
rburrow87's Avatar
Car: 1975 Pontiac Firebird Formula 400
Engine: SBC 350 w/Pro-Flo 4
Transmission: M29 T56
Axle/Gears: Stock 10 bolt w/3.42 and new Auburn
There are APYPWB (manual trans) and ARAPWB (automatic trans) to get wideband datalogging on a 165 ECM with $6E:
https://www.thirdgen.org/forums/diy-...band-data.html
I use APYPWB myself. The AFR it was reporting was wrong with my AEM UEGO Wideband setup, so I had to do some fiddling with the equation in the ADX it uses to convert the raw number into an AFR to get it within reason. ULTM8Z has a thread or two somewhere about dealing with that. I haven't gone as in-depth as he did to really get it right yet. I've been dragging my feet with tuning more on my car because the 165 randomly clamming up and the sometimes sketchy Bluetooth connection get really frustrating. I swear it can tell when the stars align and I have a window to make a nice long WOT run from 1st through 4th and so it stops communicating half the time. Considering throwing in the towel on it and going EBL Flash-II. Not trying to be discouraging, just saying to keep in mind that the 165 is known to sporadically stop streaming data.
Pretty good crash course on making history tables in TunerPro:
http://www.gearhead-efi.com/Fuel-Inj...es-in-TunerPro
Unfortunately I'm far from being good at tuning and messing with TunerPro and all that still, otherwise I'd give some advice.
Old Oct 27, 2018 | 10:04 PM
ULTM8Z's Avatar
https://www.thirdgen.org/forums/dfi-ecm/616360-repinning-7730-wideband.html
Old Oct 29, 2018 | 05:15 PM
happyhapka's Avatar
would this work for a $6E bin on a 165 ecm?
Old Oct 29, 2018 | 05:52 PM
ULTM8Z's Avatar
I don't believe so. I think all of that is specific to 7730 and $8D, especially since you need the S_AUJP bin to do it.
Old Oct 29, 2018 | 05:54 PM
happyhapka's Avatar
Has anyone attempted to do it on a set up like mine?
JeepYJv8
16
Nov 7, 2010 10:04 PM
jsup
Feb 1, 2009 11:54 AM
epsmotorsports
Apr 23, 2008 07:36 AM
adambros
Jul 7, 2004 05:28 PM
jonarotz
40
Mar 30, 2004 03:18 PM
