How do i read prom chip for bin filename?
Old Apr 29, 2019 | 04:54 PM
HSRTPI's Avatar
Car: 89 Corvette
Engine: 383, hsr intake, xr288hr-10,
Transmission: 700r4 , transgo shift kit, 3k stall
I have several changes on 4 different chips. 7 different bins modified. Finally got one that's working fairly well but cannot id it with the bin i used.
Is it possible to See the bin file I've flashed on it?
Old Apr 29, 2019 | 05:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How do i read prom chip for bin filename?
To see the bin on a chip do a read and save. Once saved load the bin into tuner pro and view.
Old Apr 29, 2019 | 05:46 PM
firstfirebird's Avatar
TunerPro also saves a .log file extension whenever you make a change in the .bin. If you open it, you can see the changes you made from the previous .bin file. This has gotten me out of trouble when I didn't do a "save as" and change the file name to trigger my poor brain memory. :/. I do a lot of dyno tuning with TPRT (albeit on BMW ECU's) which don't have any kind of data logging functions. So, I name the "save as" corresponding to the dyno run file - if I forget to do so, the problem escalates exponentially every time I forget...sorry getting off on a tangent here hehe, but hope this helps.
Also the "compare" in TP works great. Load up the previous .bin(s) and do a compare, it will point you in the right direction of the changes made in the past if you don't have the .log.
Old Apr 30, 2019 | 12:22 AM
HSRTPI's Avatar
Car: 89 Corvette
read and saved but tunerpro showed up as way off the grid numbers?
Old Apr 30, 2019 | 11:27 AM
Engine: Lb9
Transmission: M20
Check your offsets
http://support.moates.net/programmin...using-offsets/
steven72192
Sep 2, 2013 11:33 AM
MdFormula350
Apr 25, 2006 12:27 PM
AntiVTEC
Sep 5, 2003 09:37 PM
JAKEDPLAYA
Apr 18, 2003 11:15 AM
Sostar18
Aug 4, 2002 08:48 AM
