aldl Bluetooth adapters
Old Jul 9, 2019 | 05:53 AM
eutu1960's Avatar
Car: 90 C4
Engine: 385 SBC ProFlow Intake
Transmission: Auto 700R4
Axle/Gears: 3.07
Anyone using aldl Bluetooth adapters, what are your experience with them, I see two out there one from red River and one from 1320 electronics. I can not use my USB aldl cable with my new phone so I am considering one of those blue tooth adapters. Thanks
for any information.
Old Jul 9, 2019 | 06:55 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: aldl Bluetooth adapters
I have the 1320 adapter in use. Bought it two years ago. Works perfect for me with my 92 with 730 ECM and my 88 with 165 ECM.
Old Jul 9, 2019 | 02:30 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
is there any delay in the data over bluetooth.
Old Jul 9, 2019 | 02:58 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I have both the Moates and the 1320 BT. I prefer the Moates. I had more connection dropouts with the 1320. I still have some with the Moates but far less. Still, the 1320 is pretty slick.
Old Jul 9, 2019 | 06:14 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
I went and ordered the 1320 bt, they state that you can hook up a WB has anyone used it this way.
Old Jul 17, 2019 | 05:51 AM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
I received the BT adapter from and it works very well if I have time this weekend I will try hooking up the WB.
Old Jul 21, 2019 | 04:24 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
I haven't hooked up the WB to the BT adapter from 1320 yet but I did some data logging with it and seems more reliable than the old aldl usb cable from reddevilriver that I have had for years, I had no drop outs and clean data, with the usb cable I would have data spikes and it would suddenly just stop data logging. So far with the aldl blus tooth adapter I have had none of those proplems, Now I just need to figure out the WB hook up, looks easy just to hot out to try it at this time, I am a little confused about what wire to use coming from my AEM WB the white 0-5v output or the Blue Serial Output.
Old Aug 4, 2019 | 05:17 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
OK got he WB to log, I used the white wire from the WB to the orange white wire on the RJ-45 cable and then had to set the switches on the blue tooth adapter to 1 and 3 up and 2 and 4 down. Big thanks to John at 1320 for the help.
Old Aug 5, 2019 | 11:30 AM
GeneralDisorder's Avatar
The drop-out's that Tootie Pang mentioned are a problem with the 7165 ECM. They occur during live data logging on all adapters. It has nothing to do with the Moates or the 1320 adapter.
GD
Old Aug 5, 2019 | 04:10 PM
eutu1960's Avatar
Car: 90 C4
Axle/Gears: 3.07
so far I have not had any drop outs with the 1320 BT adapter, I always thought it was a problem with the CCM interrupting data from the ecm.
Old Aug 12, 2019 | 12:54 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Using the Red River BT. Once connected its very solid. Sometimes I need to disconnect and re-connect a couple of times before it ON. I find disabling WiFi on the tablet is helpful to maintaining connection.
Tootie Pang
Feb 26, 2025 05:09 AM
Tootie Pang
Aug 30, 2017 12:42 PM
RunawayRadio
May 14, 2016 05:34 PM
tunatrky
Dec 9, 2014 07:52 AM
robertf
19
Oct 25, 2012 09:20 PM
