Rich open loop idle
Old Sep 16, 2019 | 03:28 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Rich open loop idle
Hey guys,
My car is tuned in closed loop. 6E. I always had a rich open and closed loop idle. I realized I wasn't being aggressive enough with my MAF table changes. I now have a high 14's AFR closed loop idle. But the car still runs rich in the open loop cold idle. I zero'ed out the "Open loop AFR Ratio % change vs coolant temp". It made a difference. But my cold open loop idle is still mid to low 13's.
I'm not quite sure what other table I just look at the lean up the open loop idle?
Thanks!
Old Sep 17, 2019 | 06:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Rich open loop idle
Is there a open loop enrichment vs lv8?
also the open loop vs coolant should accept negative values
mid 13’s with cold coolant is fine imo
Old Sep 17, 2019 | 08:39 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks for the reply! I figure mid 13’s were ok too. But it puffs a very small amount of black smoke at cold idle. I don’t know if it’s because my Wideband is a little off due to the large cam or what.
Old Sep 17, 2019 | 09:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Could be. How the plugs look
Old Sep 18, 2019 | 03:54 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Rich. But that was before I dialed in my closed loop idle which was always rich. That's a good idea. I'll pull a plug this weekend.
getsideways
Mar 4, 2008 05:19 PM
escort_ford84
Jul 1, 2006 10:49 PM
jeepguy553
Jun 18, 2004 09:26 AM
rattle
Apr 10, 2004 03:33 PM
