Any breakthrough technology since Trax's article?
Old Jan 12, 2002 | 02:36 AM
Kersteae's Avatar
Hi all I'm a newbie and was just curious if there was any new developements that make anything in the article obsolete. I've been skimming the posts and it seems as if everything is advanceing but its hard to pin things down before I start. And if it makes a difference I have a 91 Z28 with the stock SD computor. Thanks.
Old Jan 12, 2002 | 09:05 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The biggest news since Tim put together his Introduction article is the ability to use the AT29C256 Flash Proms instead of 27C256 eproms (that came in these cars).
The Flash Prom allows you to re-program electronically via the "burner" in seconds instead of using the UV Eraser which takes 15 minutes (when the eprom is new) and then must be slowly increased as the eprom is used.
Old Jan 12, 2002 | 01:07 PM
Kersteae's Avatar
Thanks! I'll do a serch on it.
Old Jan 12, 2002 | 06:59 PM
mta227's Avatar
Ya, I would consider the flash eprom to be a VERY significant advancment!! Used along with the modified header adapter, it is about as close to an emulator as you can get for the money.
Old Jan 12, 2002 | 07:47 PM
Kersteae's Avatar
What exactly is the "modified header adapter" that you mentioned. Don't think I've come across that yet. Thanks.
Adam
Old Jan 12, 2002 | 08:31 PM
mta227's Avatar
Here is a pic :
All the info on this and more can be found in Traxion's Prom burining introduction article located here :
https://www.thirdgen.org/newdesign/tech/promintro.shtml
The modified header adapter is used to enable burining of the eprom directly through the calpak. No need for a zif socket, just solder in a 29C256 and away you go!
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
apie2546
Oct 16, 2016 02:24 PM
Formula8r89
Sep 22, 2015 04:24 PM
okfoz
Sep 17, 2015 10:30 AM
Street Lethal
Sep 7, 2015 01:09 PM
