ADS to ADX
Old Jan 25, 2020 | 05:50 PM
91CaddyBrougham's Avatar
Car: 1991 Caddy Brougham
Engine: TBI 350 5.7
ADS to ADX
Greetings all,
I'm ashamed to even ask this, but I I think I'm missing something real simple. Just trying to convert an .ads to a .adx in TunerPro, and I'm not having much luck. I have the latest version downloaded .9209.00. I'm following the directions from here:
http://support.moates.net/tprtv5-ads-to-adx/.
After I pick the file, I'm not asked to save it anywhere. The blank box on the bottom between "hardware not found" and "DA: Not Connected" loads a blue bar to halfway, and that's it.
Thanks!
Old Mar 3, 2020 | 01:20 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
Re: ADS to ADX
The process is not intuitive, and I may be doing something wrong; but here's how I've been able to do it:
Acquisition>Import Definition
Click "from ADS..."
Select the ADS file to be imported by clicking it.
You'll see the 1/2 blue banner you described and then nothing as if an error. File window closes as if nothing happened.
Click "Acquisition" again and select "Load Definition File"
Will get pop-up: "Acquisition Definition Modified, Save?
Click "Yes"
A "Select path and filename for ADX" window opens
Navigate to the folder to contain the ADX if not the current folder
Enter ADX file name (ADX extension not needed)
Click "Save"
A "Select ADX to Open" window is displayed.
Click "Open"
The ADX file is now open and the name is displayed in the top banner.
HTH, Elky
Old Mar 4, 2020 | 12:20 PM
Engine: TBI 350 5.7
Re: ADS to ADX
Thank you 84Elky, I appreciate the step by step, and I'll give this a try!
Old Aug 6, 2025 | 02:19 PM
Skii's Avatar
Car: 1987 IROC
Engine: 305 but working on 350
Axle/Gears: 3.23 Posi
Re: ADS to ADX
wow...your directions better then TunerPro's, man!!! Thank you
Old Aug 9, 2025 | 09:25 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: ADS to ADX
galletti
Jul 23, 2015 12:07 PM
jsup
Feb 1, 2009 11:54 AM
Ronny
May 5, 2007 11:44 AM
adowdell
Jun 28, 2006 07:39 AM
jwscab
Oct 3, 2004 07:02 PM
