ALDL Cable not working
Old Mar 29, 2020 | 07:24 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Just tried to connect to the car for the first time in ohhh...5 years and TPRT will not recognize my ALDL cable. Com port on laptop is set to 0001, hub 0001. Device manager recognizes it and the driver is installed, but TunerPro reports cable not found or functioning. Is there a way to test it, or is it a loss and I need a new cable?
TPRT recognizes the Ostrich 2.0, but not the ALDL cable.
ECM: 1227730 ECM
MASK ID: 8D
BIN: AUJP / 10APR2013.bin
XDF: 8D_WB_V5.XDF
ADX: 1227730_corrected.adx
Emulator: Ostrich 2.0
ALDL: OBD1 Cable with 3position switch
Software: TunerPro RT
Old Mar 30, 2020 | 06:56 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Re: ALDL Cable not working
Ok, I guess that may have been a stupid question...LOL I just ordered a new cable from Craig. Stay well fellas.
Old Mar 30, 2020 | 09:59 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Did you try all your com ports. I had the same thing happen recently with a 730. The previous com port I had tp set to didn’t work.
Old Mar 30, 2020 | 04:34 PM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Well thanks for that tip! It works on COM port 3! I guess I'm going to have a spare here shortly.
danielr1211
17
Sep 20, 2013 01:13 PM
Ruiner
Mar 28, 2012 09:13 PM
rcb1
May 13, 2009 07:02 AM
thebruce
22
May 2, 2009 06:14 PM
923.4v6
Aug 16, 2008 09:09 AM
