$1f and tunerpro
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
$1f and tunerpro
Has anyone had success gathering data from the 1226870 ecm ?
i have a few adx files and the customer has tried two different ecms. Shows connected but no data recorded.
thanks for any help not wanting to use winaldl unless I really have to.
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: $1f and tunerpro
Is that the 85 ecm? If so, I have got mine to work with that .xdf file. What .adx file are you using? I am using the one from the tunerpro website. It is A20.ads, and I just imported that through tunerpro.
Engine: Lb9
Transmission: M20
I got the a20.ads off tp site and converted in tp.
have two guys trying to use the same converted to adx.
both show connection but no data shows when recording or dashboard.
yes this is 85 tpi.
yes this is 85 tpi.
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I am not some genius when it comes to this stuff, but like I said, I have gotten mine to work. Are they happening to use the resistor in the cable? Sorry if these sound like stupid questions.
Engine: Lb9
Transmission: M20
Yes, 10k mode while running and still not data on the dash or item list.
Engine: Lb9
Transmission: M20
I’m having one guy try tp v4 but not thinking it will be successful.
