Eeprom
Old Jan 14, 2002 | 12:34 PM
tpi_roc's Avatar
Eeprom
Hey guys,
Whats the story on the EEPROM's? (these are the electronically flashable ones right?) I haven't been able to find to much info on them and did a search, if this has been covered extensivly I apologize just point me to the thread. Anyways My question is are these erassed in the burner? Just burn all 1's or all 0's to it or something similar? They cost more? where can I get some? and finally are they compatible with '165/730
Old Jan 14, 2002 | 01:27 PM
Steve10's Avatar
Yes, they are erased when you reprogram. I bought mine from Arrow Electronics (arrow.com) for $4.53 ea., part # Atmel AT29C25612PC. I have a 165, so what I did was fill the buffer with 00's and program, then set start address to 04000, end address at 07FFF, load bin to buffer and program. Leave it set this way and when you burn another revision just load buffer and hit program, it programs right over it.
Old Jan 14, 2002 | 07:05 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
For me this was one of the best posts explaining how to use the 29C256 eeproms.
https://www.thirdgen.org/techbb2/sho...ghlight=eeprom
I haven't tried it using the pocket programmer method but combining the two bin files using the dos prompt couldn't be easier. Follow either example as both will work and you'll be good to go.
Old Jan 15, 2002 | 12:55 AM
Greenshamrock77's Avatar
I am ready to order some 29c256's, went to arrow.com and found that $19 shipping, and $11 for handling was out of line. Is there a place that has reasonable S+H charges?
Old Jan 15, 2002 | 07:06 AM
Steve10's Avatar
I think you can get them from several sources, but most will have a minimum order qty., or S&H charges. Get a few people together to meet the min. order, that's probably the best way. Whatever the cost I guarantee you will wonder why you didn't do it sooner.
Old Jan 15, 2002 | 10:27 AM
tpi_roc's Avatar
Sounds great to me because I sure dont like the cost of the UV eraser
How long do the EEPROM's last in compairison?
Old Jan 15, 2002 | 02:28 PM
v8power's Avatar
the eeproms are good for around 25,000 write cycles so you have alot of burning to do to wear them out
I have mentioned this before order the chips as samples from Atmel you can get one or two (thats all you need) for free no shipping costs or anything
www.atmel.com has them
rsilver
Apr 28, 2004 01:53 AM
ski_dwn_it
Oct 5, 2001 02:19 PM
okfoz
Jun 21, 2001 10:11 PM
Kevin91Z
52
Mar 31, 2001 10:59 AM
