Converting .bin file to .txt file for printing
Old Jun 9, 2020 | 06:33 PM
elesone's Avatar
I did this once before (8 yrs ago), but I cannot remember how I did it. I exported the .bin file to text, but all I got was zeros or -40*. I searched this forum and GEARHEAD-EFI, with no success. Possibly wrong wording.
Here's what I want to do. Review the differences between AXXD (5.0L 5 spd) and AXXF 5.0L auto) by printing the text files and compare them. What would be good is input the text files in a spreadsheet or word processor, but I think the files will not have the exact number or same lines.
Questions:
1. Is there a thread already posted which I missed?
2. Does TP have to communicate with the ECM?
3. Is the reason why I got zeros, because my laptop was NOT connected to the ECM?
4. Is it possible to join the files by importing the text files in a spreadsheet or word processor?
Hope I did not miss an existing thread and repeat the topic.
Old Jun 9, 2020 | 06:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Converting .bin file to .txt file for printing
Is bin compare not good enough for this ?
Old Jun 9, 2020 | 06:51 PM
elesone's Avatar
Can I print a .bin file so an inexperienced person like myself can read every line? I'm open for suggestions.
Old Jun 9, 2020 | 07:09 PM
Engine: Lb9
Transmission: M20
Load the $8d xdf, load the bin you want to print.
Click file tab export data to text file. Save then print the text file.
Old Jun 9, 2020 | 07:14 PM
elesone's Avatar
I did that as stated in my opening post, but I got zeros. Hence my question #2, does the laptop require connection to the ECM?
Thanks for your patience.
Old Jun 9, 2020 | 07:16 PM
Engine: Lb9
Transmission: M20
No connection needed but you need the xdf loaded. Just tested works fine for me.
Old Jun 9, 2020 | 07:25 PM
elesone's Avatar
At the top of the screen, it lists all three files, xdf, bin and ads every time I run TunerPro RT. I don't reload any of the files before connection via ALDL. No problem viewing the dash screen to monitor the engine.
Old Jun 9, 2020 | 07:29 PM
Engine: Lb9
Transmission: M20
Ads ? V4 ?
Old Jun 9, 2020 | 07:35 PM
elesone's Avatar
My bad, adx v5. Glad you're on the ball to straighten this amateur.
Old Jun 9, 2020 | 07:54 PM
Engine: Lb9
Transmission: M20
send me a pm with your email. im having trouble attaching a zip here. i have converted axxd and axxf for you to text
Old Jun 9, 2020 | 08:01 PM
elesone's Avatar
Thanks, but how do I pm you?
Old Jun 9, 2020 | 08:04 PM
Engine: Lb9
Transmission: M20
click on my profile, then select private message
Old Jun 9, 2020 | 08:08 PM
elesone's Avatar
Done. Thx.
Old Jun 10, 2020 | 09:25 AM
Engine: Lb9
Transmission: M20
Is that what you wanted?
Old Jun 12, 2020 | 02:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Need to load the BIN into TunerPro:
File->Open BIN
The BIN needs to be on your PC/laptop for this. TunerPro won't download it from the ECM.
RBob.
Old Jun 12, 2020 | 07:03 PM
elesone's Avatar
Thanks fellas. I opened a couple of different bins and was able to export them and print a couple of pages to verify. When I re-opened the concern bin, I got the zeros again. The item description is there but the data shows a zero or -40*. So I must have done something wrong when I exported to a text file. But all is good again and can carry on with my project.
ninetyone
May 15, 2011 03:14 PM
bigsmlblks
Jul 21, 2005 09:12 AM
CaddyDaddy
Jun 17, 2004 09:09 PM
Greg
Jan 16, 2004 05:21 PM
86 IROCZ28
Jun 7, 2002 09:17 PM
