EBL Help Needed!
Old Oct 20, 2020 | 05:55 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
EBL Help Needed!
So I have installed the flash II and flashed the 5.7 TPI bin, I think it was 3005. I then went to start the car and it will stumble for like 0.5 second like one or two cylinder fire and then stall. How do I fix this?
Also, is MAP sensor supposed to read 1 Bar when car is on but not running?
Old Oct 21, 2020 | 09:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Help Needed!
Likely running rich due to the displacement and injector flow. Set up the BPC - BPC vs VAC table first, then flash that BIN in.
As for the MAP, yes, key-on, engine-off should be at about 100 - 104 KPa (due to your location).
RBob.
Tim C
Jun 24, 2017 09:09 PM
TPI-Formula350-
Mar 15, 2010 02:34 PM
Six_Shooter
Feb 2, 2009 10:11 AM
northern-tpi
Aug 1, 2006 05:59 AM
