If I have a MEMCAL and wanted to burn a copy, how best to accomplish?
Old Dec 27, 2020 | 05:19 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
It's a 1989 Memcal PROM, How best?
In Connecticut, if it matters.
Thanks.
Old Dec 27, 2020 | 07:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: If I have a MEMCAL and wanted to burn a copy, how best to accomplish?
Are you running a custom tune or are you just wanting a stock uv erasable memcal reprogrammed ?
Old Dec 28, 2020 | 06:26 AM
Big&BadGTA's Avatar
It's a custom calibration on the prom. Thanks
Old Dec 28, 2020 | 08:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Go to moates.net and get the Burn2 and a few PROMS. Use the Burn2 to read the current PROM and to burn another. If the PROM is soldered into the MEMCAL, then grabbing the HDR1 is also recommended.
RBob.
Old Dec 28, 2020 | 11:24 AM
Engine: Lb9
Transmission: M20
or a uv eraser and a pocket programmer will work but it’s alittle more expensive.
Old Dec 28, 2020 | 02:16 PM
Big&BadGTA's Avatar
RBob.
Thanks. Is it a difficult process?
I have the memcal, I can just program duplicates? Sounds easy......
http://www.moates.net/gm-19851995-c-64.html
Old Dec 28, 2020 | 03:02 PM
Engine: Lb9
Transmission: M20
You might want to identify the chip on the memcal first or just get the burn 2 a sst27sf512 and g1. Easy to do a read and flash. Just erase the eeprom before reprogramming and check offsets for a 16k file size. All information on moates.net
SBNova
41
Nov 30, 2004 02:33 PM
