Copy from compare bin
Old May 25, 2021 | 08:05 PM
dusterbd's Avatar
So, im trying to add the spark table from one bin to another.
i have tunerpro open, and have the bin im running open, and the bin whose spark table i want to ise set as the compare bin.
when i use function:cpy frm cmpr and then click execute, i get a gibberish table in return.
What am i doing wrong? All i want is the spark tables from a 4l60e bin to copy into my 4l80e bin....
Anyone have a write up, video, walk through, something?
Thanks!
Old May 26, 2021 | 07:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Copy from compare bin
Should work, be sure to highlight the whole SA table by clicking on the upper left most square. Also, both BINs need to be the same MaskID. Use the compare icon to see what is going to be copied over. That will show if the data being copied is from the same table location within the BIN.
RBob,
Old May 26, 2021 | 07:55 AM
dusterbd's Avatar
RBob,
i had been using the compare to make sure, and wound up with negative timing numbers where there shouldn't be any, etc.
Bu, i have been dragging the mouse to highlight all the cells. Will try clicking the single box when i get back to the house.
Old May 26, 2021 | 07:20 PM
dusterbd's Avatar
RBob,
crap. never noticed different Masks. one is $0D, and the other is $0E.
is there a workaround?
Old May 27, 2021 | 07:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check that the columns and rows match up between the two. That is the KPa and RPM. If they do can copy from one, and then paste it into the other. May need to use Excel as an intermediary.
Be sure to switch the XDF file between the copy and then the paste.
RBob.
3.8TransAM
Feb 8, 2012 07:51 PM
Ronny
Aug 10, 2011 02:47 PM
Fast92RS
Aug 14, 2006 08:34 AM
sparks454
Sep 8, 2004 07:30 PM
