anomaly WU dalalogs
Old 06-15-2021, 09:50 AM
Ronny's Avatar
anomaly WU dalalogs
I had my Innovate WB reporting to its software in controller and to pillar gauge. I recall them showing the same data as far as A/F.
I then patched into EBL-WU and I do not recall then reporting a differing A/F from pillar gauge. The WU is regularly showing 1.5 points leaner and sometimes the same as pillar gauge .
Is there an offset that needs an adjustment in EBL for that deviation?
Thank you!
Old 06-15-2021, 01:05 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: anomaly WU dalalogs
You need to set the WB controller to report zero volts for 7.5 afr and 5v for 22.39afr
Old 06-15-2021, 01:51 PM
Ronny's Avatar
Thanks. I will did up owners manual....
Old 07-20-2021, 10:36 AM
Ronny's Avatar
Innovate automatically sets at that V by user selecting fuel in use. In my case E10. Stoich is reported at 14.7/1 or 1.0 Lambda,
freaky
03-20-2012 01:17 PM
V8 Slayer
02-07-2008 08:35 PM
Quick Reply: anomaly WU dalalogs
