Please explain how the $32B and $6E bins eproms work.
Old Jan 17, 2002 | 08:33 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The '87 $32B definition file from Tunercat shows that there is a switch table, a constants table, and 23 other tables. The base pulse width method is checked in the switch table. There is no air/fuel ratio target in the $32B stuff. This leads me to think that the fuel injector pulse width is determined directly from the various tables and sensor values as you drive the car.
The '89 $6E defintion file shows a switch table, a constants table, and 31 other tables. The constants table has a target air/fuel ratio value of 14.7 and many of the other tables work on a percentage change to that air/fuel ratio. So as you drive the car, the various tables that are addressed result in an air/fuel ratio of something other than 14.7.
Do I have this correct?
Can anyone shed more light on this for me?
I have had alot of trouble with the 33 error code, what do I do with a 395 cu in engine using a MAF relating to this error code? What is the theshold constant that Adam referred to in my other post?
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
vanceh
Feb 1, 2003 07:28 AM
Allan
Aug 11, 2002 08:58 AM
JPrevost
Nov 6, 2001 03:01 PM
MJT
Dec 19, 2000 08:11 PM
