Convert .bin to EBL file
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
I need a refresher. How do you convert stock .bin files to use with the EBL P4 .xdf definition in TunerPro?
I want to compare a stock '90 corvette .bin file with my current EBL .bin files, without converting the old file it just shows up as unusable data in TunerPro.
Thanks!
Thanks!
Car: check
Engine: check
Transmission: check
Re: Convert .bin to EBL file
Open the stock $8D BIN in TunerPro using the proper $8D XDF file. Open the tables you want to compare, do a screen snap shot (ALT+PRNT SCRN) then paste into your favorite image program.
Switch to the EBL XDF file and open the EBL BIN. Can now compare those tables to the ones from the $8D BIN.
RBob.
RBob.
Is there a way to convert the entire $8D bin to an editable EBL file I can load into the ecm?
