TCC's all set to 16mph
Old Dec 6, 2021 | 06:27 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Hi guys,
I'm running the arap.bin with Tuned Performance's $6E.xdf file.
Scalars: All of the lock, unlock and the prevention speed are set to 16MPH. Coolant enable is 16C.Minimum load hysteresis is 16%TPS. Minimum high/low speed threshold is 16MPH. I'm sensing a pattern here.
If I drive in Overdrive, 1-3 shifts are nice and strong, especially 1-2. However, it surges when shifting into OD, going right back into third.
Should I leave everything as-is or should I adjust them? Running around in D is fun as hell but I'd still like to use OD. Any advice?
Old Dec 8, 2021 | 07:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TCC's all set to 16mph
Something isn't right about what you are seeing. The stock ARAP BIN isn't set up that way.
Does the trans have the high gear switch to the ECM? If so you can set up the high gear (4th) tables to lock at a higher MPH.
RBob.
Old Dec 8, 2021 | 07:59 PM
Johnny Gun's Avatar
Car: '88 GTA
RBob.
I don’t know what that is or where to find it. I’m using TunerPro.
Old Dec 8, 2021 | 08:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Dec 9, 2021 | 05:52 AM
Johnny Gun's Avatar
Car: '88 GTA
Oh! I thought you were talking about a setting in the bin. I'll check the connection. OD has always worked before, but I haven't really driven it since I uploaded this burn.
guy72
Jan 7, 2021 03:53 PM
Jeep_Joint
Oct 17, 2012 09:00 AM
guy72
Aug 21, 2007 12:51 AM
87zjeff
30
May 15, 2007 10:36 AM
MikeT 88IROC350
Jul 10, 2001 11:22 PM
