Default Startup o2 Voltage
Old Oct 16, 2022 | 04:37 PM
ULTM8Z's Avatar
Does this need to be closer to the values used used in the Fast O2 Rich/Lean Threshold vs MAP?
For example, my Fast O2 settings are into the .650 to .750 range. But the default start up voltage is .451 (stock AUJP).
Old Dec 31, 2022 | 10:58 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Default Startup o2 Voltage
Have you ever found an answer? I was wondering same.
On my $6E APYS OEM, the default is set at .566 and Fast O2 into 0.500 to .642 range
On my $8D ATNX OEM, not in idle mode, the default is set at .451 and Fast O2 into 0.522 to .628 range
On my $8D ATNX OEM, in idle mode, the default is set at .451 and Fast O2 is .598
Old Dec 31, 2022 | 02:37 PM
ULTM8Z's Avatar
No answer yet..
AUJP/ANHT stock calibration also set at .451 default and .522 to .628 for non-idle Fast O2 thresholds
Old Dec 31, 2022 | 04:08 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A cold O2 sensor reports nothing, the output impedance is too high to to affect anything. The O2 sensor amplifier input is weakly biased to about 450 mV.
Until the O2 sensor is up to temperature it can't produce an output.
The ECM seeing 450 mV won't go into closed loop. The sensor needs to be active and go above and/or below certain value(s) to be 'active.' Only then will the ECM go into closed loop.
RBob.
Old Dec 31, 2022 | 04:45 PM
ULTM8Z's Avatar
So it's just an arbitrary value for the ECM until the O2 starts generating a usable signal? In which case it has no bearing on closed loop operation?
Old Jan 1, 2023 | 03:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not arbitrary, need to be sure that the ECM doesn't think that the O2 sensor is active. Otherwise it could go into closed loop with an inactive sensor.
RBob.
petrolhead
Feb 14, 2013 02:38 PM
nomad350Z
Aug 23, 2008 07:58 AM
DAIGS1985
May 9, 2006 12:33 PM
z28bill
Apr 28, 2002 08:38 PM
Grumpy
May 29, 2001 03:53 PM
