Low Octane Knock Retard.
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
So, I found these 2 tables in S_AUJP, which are mulitpliers. One based on MAP, and the other based on RPM. I have entries in both tables, integers of 1.00 or less. In the description, it mentions that all these values (S_AUJP) are =0, so this feature is disabled. Is there some kind of low octane sensor, in my ride, that would trigger to use these tables?
I am looking at this for tuning SA in my '90 C4 L98 ride.
Car: check
Engine: check
Transmission: check
Re: Low Octane Knock Retard.
The knock detection and reporting system is used. Which is basically the knock sensor and ESC filter (on the MEMCAL).
IIRC, it has been awhile, this feature (!?) is used to retard the SA for the duration of key-on, engine-running. Thereby preventing knock from occurring. Or something like that.
RBob.
RBob.
Car: 1988 IROC-Z
RBob.
RBob.
The only 0's I have in my tables, are at MAP of 20,25,30.
I'm just wondering how does the ECM know you have low octane fuel in the tank?
Car: 1983 G20 Chevy
Transmission: 4L60
Interesting. So, can we just forget about the phrase "low octane", WRT this parameter? Obviously a multiplier in these tables, gets used in the code to calculate a value for knock retard. Thus, a multiplier of 0 x anything=0. So, can we say that these tables can eliminate knock retard, totally, in the bin?
These settings are more a failsafe for a tank of bad gas.
Car: check
Engine: check
Transmission: check
MikeT: an oldy but a goody, I knew a former mod dissected this feature (?), and did a decent write up on it:
https://www.thirdgen.org/forums/diy-...d-routine.html
Hopefully it answers some questions.
RBob.
RBob.
Car: 1988 IROC-Z
RBob.
RBob.
And, by the way, I did perform a search on this subject, before posting, but certainly did not go back to 4/16/2001 to read the answer!
doc
Sep 15, 2004 11:35 PM
Grim Reaper
30
Mar 31, 2003 03:12 PM
