Anyone bored and want to look at my datamaster file?
Old Jul 23, 2005 | 03:33 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I finally got it to work. The only thing that concerns me is a I get a lot of knock retard when I floor it. So I did a 40mph to 75 mph WOT run, and I got a big spike of retard as soon as I floored it, but as I stood on it, the knock counts kept getting lower and lower.
Heres my datamaster file
I removed the 10k resistor as soon as I started getting data.
Old Jul 24, 2005 | 09:35 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I took a look at it and don't see any relation of knock to the retard you are getting. Retard was minimal when you first got on it at around 40 but no knock counts were there and the retard went away quickly. The reduction in spark "appears" to be from your table settings in the high MAP areas. The advance dropped directly with the map readings.
Old Jul 24, 2005 | 11:50 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks for taking the time to look at it, I appreciate it.
This is what I was talking about as far as the knock retard when I first go WOT @40mph:
But the longer I stay on it, the less knock retard I get. Here I am on the same run but at 70mph still at WOT:
It also seems I am pretty rich under normal throttle conditions:
I'm just trying to understand this stuff so I can attempt to write my own chips. I read through the datamaster help file, but it didn't help much as far as what values are acceptable.
Old Jul 24, 2005 | 05:19 PM
JP86SS's Avatar
Smack me in the head! I looked at in with $8D.
No wonder there were no counts. Strange how the data seemed good when I viewed it though ???
Old Jul 25, 2005 | 03:20 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Is that knock normal?
Old Jul 25, 2005 | 05:06 PM
JP86SS's Avatar
I still havn't downloaded the MAF version, but The best i can say is to try and get rid of the knock. One or two counts "could" be interpeted as normal but not enough knock to cause retard. If it is because of leaning out you could give it more fuel or less spark. Experiment with AE a little and see if that yeilds any answers.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
hartsmike
Oct 2, 2015 07:11 AM
