EBL Flash With Msd distributor and MSD6 wiring
Old Jun 16, 2023 | 09:19 AM
Bigsweed666's Avatar
Car: 1970 Firebird Formula
Engine: 462 CBB
Transmission: 4L80E
Axle/Gears: 4.11 Mooser 12bolt in 4-link
Hi
Any tips on how to wire the EBL without Spark control.
Im running a Msd distributor and a MSD 6AL2 and i would like to keep that for now, but how do i get the Tacho signal in to EBL flash so it knows the engine is running?
Im guessing D4 EST but it would be nice if someone actually knew how to do it
/Orjan
Old Jun 17, 2023 | 05:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Flash With Msd distributor and MSD6 wiring
EST pin D4 is an ECM output. Do not connect to anything and do not short it to anything..
BYPASS pin D5 is an ECM output. Do not connect to anything and do not short it to anything..
For a distributor reference pulse (DRP) input to the ECM...
Need to provide a 5V square wave input on ECM pin B5 (RefHi). NOTE: 5 Volts, NOT 12 Volts.
Need to provide a ground input from that device to ECM pin B3 (RefLo).
Clear the MALF 42 code flag in the BIN.
RBob.
Old Jun 18, 2023 | 02:11 AM
Engine: 462 CBB
Transmission: 4L80E
HI
Ok.
So it need to be connected over a HEI control module or something like it.
/Örjan
Old Jun 19, 2023 | 03:13 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Or use the 6AL2 tach output and level shift it down to 5 volts.
RBob.
onthedownlow
May 8, 2013 06:21 PM
2QUIK4U
Aftermarket Product Review
Sep 16, 2010 09:30 PM
91tirespin
Jan 28, 2004 04:13 PM
