Searching for bin and question about camaro vs firebird
Old Jun 29, 2023 | 08:55 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hey yall,
I am finally getting my car buttoned up again. The goal is to have it run as well as it can in stock form.
I've finally installed a set of the Delphi fuel injectors and got rid of the Bosch, and I installed a nice set of MSD 8.5 wires, checked all my spark plugs, and installed a new fuel sender.
My question is about the bin files.
When I was working with the Bosch injectors I was attempting to tune the tables, not to much success I suppose.
However I was using the 9375 ANYX from the 89 firebird with g92/3.45 gears manual, 5.0
I've nixed the cold start injector and ideally would like to use a direct upgrade to my current bin which is... a 2423 AKFW.
I was told the bin im looking for is either 9350 APYS or
9350 ANYS. I cant find either of these.
Was there many differences between the firebird and camaro bin?
Any info would be appreciated!
Old Jun 29, 2023 | 09:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Searching for bin and question about camaro vs firebird
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
http://www.gearhead-efi.com/gearhead...%206E%2094/6E/
Old Jun 29, 2023 | 09:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Attached is APYS, supposed to be a stock BIN. It is a '89 Camaro, 5.0, TPI, 3.08 with a T5. The ANYS I don't find, not sure if it is a valid BCC or not.
RBob.
File Type: bin
Old Jun 29, 2023 | 10:13 AM
Engine: Lb9
Transmission: M20
Any of these would work
Old Jun 29, 2023 | 12:06 PM
Annihilate's Avatar
Engine: 5.0
Thanks guys, yall rock.
Stuman
20
Apr 17, 2018 11:40 PM
Farmer Mike
May 19, 2005 03:22 PM
Frank88
Jun 23, 2002 10:26 AM
