SES Light with EBL
Old Jul 3, 2023 | 01:17 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
SES Light with EBL
I thought I had my tune nailed down. But every once in a while I get a SES light. It usually happens before the engine is warmed up. I finally got a datalog of the error. In the attached file, the ses light comes on at 3:40. PE mode turns on just before. TPS is only at 22 so PE shouldn't have come on. Also uploaded is my current bin.
Thanks.
File Type: csv
File Type: bin
Old Jul 3, 2023 | 05:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: SES Light with EBL
OK, what malfunction code is being set???????
RBob.
Old Jul 3, 2023 | 09:23 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
42
Old Jul 4, 2023 | 09:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good 'ole code 42. Could be from a slew of different items. Basically the malfunction is caused by a miscount of outgoing EST pulses (from ECM) and incoming DRPs (from distributor).
The condition of the distributor is paramount, then the wiring between the coil and distributor, and the wiring between the ECM and distributor. Then of course the ECM itself.
RBob.
Old Jul 6, 2023 | 11:08 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Wiring looks fine. It did it again today. At 2:33 and 5:39 on attached csv. It's like the engine shuts down for a split second.
File Type: csv
Old Aug 4, 2023 | 08:22 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by JJ63
Wiring looks fine.
lol I'm sure they look fine... but did you ohm them?
- Rob
Old Aug 7, 2023 | 03:19 PM
???'s Avatar
the pick up coil has caused me to chase my tail twice over the years with tpi cars. I now change then when I have a dizzy out if the look really old
Blue86Firebird
Dec 13, 2021 10:25 AM
kevo2k6
Dec 17, 2004 08:05 PM
86BIRD-MY FIRST CAR
Mar 6, 2002 12:33 PM
