what is the timing logic in ebl flash II
What tables are adders and how is total timing calculated? I know that you set your main and extended tables. Adders for IAT/ECT will add or subtract. I am also aware that the PE will add additional timing. What is the login path to come to actual timing?
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: what is the timing logic in ebl flash II
I am sure it has been specifically stated somewhere on the site or in the main EBL thread at some point but without some heavy searching it might be hard to find.
However I am sure you would find a significant magnitude of similarities from EBL to the SA Logic thread mentioned in the Prom Tuning Guidebook. Seen here https://www.thirdgen.org/forums/diy-...cs-anyone.html
What exactly are you trying to figure out or achieve?
