dabomb6608
close
As many know, Robert passed away last summer (RIP to a great man) and now the website is officially down. Thankfully I had pulled every download available from the site prior to this. I am attaching them all in zip files. You can also use "TheWaybackMachine" website to view the website as it was through the years. This includes back in the late 00s early 10s when the how to install flash guide was available. Links below.
https://web.archive.org/web/20250000...ynamicefi.com/
https://web.archive.org/web/20240930...ynamicefi.com/
Hopefully a mod will see this and make it a sticky and maybe even lock it?
- EBL_Flash_2-7.zip (591.4 KB)
- EBL_P4_Update_1-2.zip (8.75 MB)
- EBL_P4_V12a.zip (39.2 KB)
- EBL_SFI6_Update_1-1.zip (8.82 MB)
- Setup_TT1-.zip (5.81 MB)
- WUD_Classic.zip (295.8 KB)
- WUD_Flash (1).zip (298.3 KB)
- WUD_P4.zip (297.5 KB)
- WUD_SFI6.zip (297.6 KB)
Thankyou, I just recently heard the sad news of Robert passing.
I have been putting an engine together for a hot rod project running a 5.7 vortec with ramjet 7395 cam, 1.6 roller tip rockers, 670 cfm Holley TBI and EBL Flash.
I have now copied all of your shared information, but am looking for the vortec F3000 bin files.
Can you help with that please?
Hope this helps!
- EBL_F_P4.BIN (32.0 KB)
- EBL_P4_3000.BIN (32.0 KB)
- EBL_P4_3001.BIN (32.0 KB)
- EBL_P4_3002.BIN (32.0 KB)
- EBL_P4_3003.BIN (32.0 KB)
- EBL_P4_3004.BIN (32.0 KB)
- EBL_P4_3005.BIN (32.0 KB)
- EBL_P4_3006.BIN (32.0 KB)
- EBL_P4_3007.BIN (32.0 KB)
- EBL_P4_3008.BIN (32.0 KB)
- EBL_P4_3009.BIN (32.0 KB)
- EBL_P4_3010.BIN (32.0 KB)
- EBL_P4_CALs.TXT (828 Bytes)
Would be great if you had the instructions on wiring a WB O2 sensor!!! I had the instructions but unfortunately they are lost.
Thanks for the help!!!!
Just use the wayback machine
Did anyone happen to get a copy of EBL Classic 1.26 from Bob? Apparently you still had to email him for it so it can't be downloaded from the wayback machine.
https://web.archive.org/web/20240229...ateClassic.php
Also was there ever an update to the XDF after v19? That's the last version I got from Bob (back 2007) along with a binconverter for it. Curious if anything changed in the bin structure after that. Thank you (RIP Bob
The only post I found from Bob talking about 1.26:
https://www.thirdgen.org/forums/diy-...ml#post4574367
)The only post I found from Bob talking about 1.26:
Just curious, are you actually using something that was created back in 2007 still? If so, I would think about upgrading when available again. I'm planning on some VERY cool upgrades. Maybe...."EBL Flash III"?. I can't go into it now, but as time goes on and after the re-installation of the EBL Flash II box. Everything takes time, but it should happen.Originally Posted by ericruhl
Did anyone happen to get a copy of EBL Classic 1.26 from Bob? Apparently you still had to email him for it so it can't be downloaded from the wayback machine.https://web.archive.org/web/20240229...ateClassic.php
Quote:
Yes indeed, 2006 actually. Still working great but I saw only too late that there was an update available that might have been useful. So still hoping someone has that zip file they can share.Originally Posted by Buccaneer
