First Burns
Old Jan 24, 2002 | 09:49 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
First Burns
After about about a dozen burns, I finally got the BLM's below 128. I had to lower the fuel inj constant to under 19 lbs, (I'm running Accel 24lb's). It still idles at a around 140 BLM. I'll have to start adjusting the VE tables.
I assume my goal is have it running at 128 BLM at ALL times, right?
Thanks for everyones help, I couldn't have done it without this BB.
Old Jan 30, 2002 | 09:09 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Hmmm, that is too much "off" for 24#, and generally the programming tends to be overly rich than overly lean - are you SURE that you didn't get 19#s by mistake?
On the idle, if you are SD, you can give extra fuel to the lower RPM (600-800) around 35-45 kpas. But often, the problem may be a lower voltage while idling, especially if you have underdrive pullies. Changing the Battery Voltage vs Injector PW usually helps with idle, especially if you are noticing a voltage drop while idling.
What mods, which ECM, etc?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Logan Bryant
Sep 23, 2015 06:51 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
