S_AUJP suggestion box?
Old Jun 13, 2025 | 11:01 PM
ULTM8Z's Avatar
If anyone is still dabbling in the S_AUJP...
Possible update suggestion on the next release?
Adding a table for AE Delta MAP scale factor vs RPM?
https://www.thirdgen.org/forums/diy-...ml#post6561700
I've been trying to see how to do it on my own from the thread in that link, but this code stuff is too much for my mechanical brain...
Old Jul 2, 2025 | 10:07 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: S_AUJP suggestion box?
Still dabbling, not getting much done.
maybe the A/C request issue will get things moving again.
1.) I still get a hiccup every once in a while, not sure but started at V5 and have wanted to investigate if moving some code to segmets is causing it.
2.) My bits display for AE, and stuff don't seem to log correctly anymore.
not sure when they broke. Thinking when they moved from low memory location.
3.) Want to revisit Launch Mode, had it working well then lost the handle on it after other mods to my setup. Maybe just needs a description clarification so I don't set it up backwards 😁
4.) Revisit the O2 table adjustment spreadsheet and make coolant "counts" not mV. Made graphical adjustment of all three tables, windows a bit easier to work on in unison.
5.) Work on a way to adjust the IAT, or just understand the effects, etc on the tables again. That can be highly beneficial to response.
those are just from memory, what's left of it.
Any other ideas?
Old Jul 3, 2025 | 10:44 AM
ULTM8Z's Avatar
Thanks for chiming in here JP. And as always, loads of thanks to folks like you and Elky who continue to keep this hobby going.
My main thing I guess is more fidelity on AE adjustibility as a function of RPM.
darryls89
Dec 16, 2009 09:46 PM
five7kid
Mar 14, 2008 11:00 AM
5.7RamJet
Jun 8, 2007 06:52 AM
tanager11
Nov 12, 2004 12:43 PM
V8Astro Captain
Feb 24, 2003 02:13 PM
